- Joined
- May 2, 2020
- Messages
- 895
I've been using a self modified version of the App for some time. I thought maybe it might be useful for others and decided to release my modifications: https://github.com/aluveitie/Aureal/releases
![Screenshot 2021-08-16 at 14.34.48.png Screenshot 2021-08-16 at 14.34.48.png](https://forum.amd-osx.com/data/attachments/3/3869-51a5540ab0ec5d3a6fc5a3e74b733855.jpg)
Your latest update is missing the pre built App.That's another update![]()
I don’t now exactly how that is linked to Aura. But in my experience from the Corsair Vengeance Pro RGB, RAM RGB is controlled through the SMBus, which is not that easy to access on MacOS… and would be very dependent on each type of RAM.
I had to switch out my Corsair RAM for lower profile ones to make room for the reservoir when I put in my custom loop. Therefore I have no way to test even if I had any idea how to implement it.
Aureal is for ASUS motherboards only.Good morning guys,
Aureal works only with Asus Mobo or can I check the LEDs even gigabyte cards?
I wanted to fix the PC's LEDs because it became a Christmas tree ... especially the RAM (crucial ballistix) is very annoying.
Good morning guys,
How can I do?
Guys I tried to install liquidctl but I don't understand how to do it, do I have to open a dedicated 3d?
