- Joined
- May 22, 2020
- Messages
- 26
Hello guys,
some may know me from my Hackintosh HowTo Videos and my Github Repo.
I was using Intel Hackintoshs in the past, but now switched to AMD.
I think I can finally share my EFI here. Currently I have no issues to fix and I would call this EFI pretty solid.
Last thing I had to solve was USB-Port Mapping via SSDT and a Wake issue, that it took two keypresses to wake the display.
Github Repository: https://github.com/SchmockLord/Hackintosh-ASRock-B650M-Riptide-7800X3D
The only thing that could be better is my Geekbench Scores.
Windows:
MacOS:
Notes:
Windows:
MacOS:
Notes:
- iGPU is causing a crash on wake if enabled. Disable iGPU in BIOS or disable it via Device Properties in your config.plist just for macOS
- Two Keypresses to wake display after sleep was solved by using SSDT-USBW.aml + USBWakeFixup.kext + Adding acpi-wake-type=01 for every USB controller (XH00, XHC0, XHC1 and XHC2) in the device properties.
- USB-Port Mapping is done via SSDT-USB-B650M-Riptide.aml:
- XH00 is defined in DSDT.aml.
- XHC0, XHC1 and XHC2 are defined in SSDT-USB.aml.
- I had to fix all errors in DSDT.aml and removed USB-port definition from the DSDT.aml.
- I also deleted the original SSDT-USB.aml. The USB-Port Mapping for all controllers is in the SSDT-USB-B650M-Riptide.aml.
