AMD Athlon×4 641 need help
lh63433
i5 10400F
中央处理器: AMD 速龙™ II X4 641
板:生物之星A55MLC FM1
显卡:GT610
我想安装 10.13.但是,遇到了问题
I don't think your Athlon II x4 641 CPU contains the correct and essential Instruction sets, i.e. SSE4.1 & SSE4.2 for running macOS. It is an old 4-core FM1 CPU from the 012h family, so it is not one supported by the OC AMD Vanilla guide.
Reactions: ExtremeXT
是的,没有 SSE4.1 或 SSE4.2。明白了。我要试试变色龙。谢谢 🙏
By the way, can 10.13.6 be installed if chameleon is used? Thank you.
Changing the bootloader won't make a difference. You need a patched AMD Kernel for your old system to b able to run any version of macOS.
You should have a look at the AMD Development section over at InsanelyMac. You may find a solution to your issues over there, as a number of AMD Kernels that allow users to run older versions of macOS are available on that site.
You will need to read and understand how you should use an 'AMD' Kernel.
I used a few of them years ago, when running OS X on an old HP server, which used the AMD Turion II Neo CPU. They worked, but not as well as newer CPU's work with the Vanilla Kernel.
更改引导加载程序不会有什么不同。您需要为旧系统修补AMD 内核,以便能够运行任何版本的 macOS。
您应该查看InsanelyMac的AMD开发部分。您可能会在那里找到解决问题的方法,因为该站点上提供了许多允许用户运行旧版本macOS的AMD内核。
https://www.insanelymac.com/forum/318-amd-development/
您需要阅读并理解如何使用“AMD”内核。
几年前,我在旧的HP服务器上运行OS X时使用了其中的一些,该服务器使用了AMD Turion II Neo CPU。它们工作,但不如新CPU与香草内核的工作。
好的,非常感谢
