ALC892 No way to get any sound
Seyven
I've tryied almost every layout and yet I can't make it work. 0 Sound going thru Realtek.
I'm using OpenCore 0.6.1... It works somehow with Voodoo, but the sound is crap with it...
Ryzen 2600X
RX 580 8GB Powercolor
16GB RAM
B450 Gaming Plus (not MAX)
ALC892
Neither Sleep Mode.
  • Kexts.rar
Have you tried all the layout id's listed for your codec using alcid= ?
maclinux1960
Hello Seyven, your Audio is supported, see: https://github.com/acidanthera/applealc/wiki/supported-codecs
Here what I found:
RealtekALC8920x100302, layout 1, 2, 3, 4, 5, 7, 12, 15, 16, 17, 18, 28, 31, 90, 92, 97, 99
Try all id's in the boot args with changing the alcid like alcid=2, alcid=3 and so on:
keepsyms=1 debug=0x100 npci=0x2000 alcid=1 -lilubetaall vsmcgen=1 agdpmod=pikera
Regrads from Germany, maclinux1960
Seyven
Yeah, I've tried every single layout...
apriliars3
If no works any layout, how can fix it sound on Big Sur? On Catalina works perfectly, but with Big Sur no sound.
eye
I also use ALC892 and at first mine also not worked. But I somehow fixed it. Here is my config. Check out device properties section and try add this to yours. And make sure u use the last version of AppleALC.kextScreen Shot 2020-11-26 at 14.16.32.png
