- Joined
- Jan 1, 2022
- Messages
- 5
Hi Folks!
I have already:
Ryzen 5950x
Asus ROG Crosshair VIII EXTREME X570
I need a compatible GPU that matches the following criteria:
Alternative Solution B:
If I don't find a silent GPU with 2 DVIs, or that LINDY extender does't work, got to control the computer from the second room on my Mac Mini via Shared Screen / ethernet (worst case).
Alternative Solution C:
If there is really no silent GPU, then please propose a GPU with 2 DVIs.
Thanks
I have already:
Ryzen 5950x
- Only music production (DAW), no video, no gaming, no motion
- Mojave is a must for me.
- Silent, passive (if possible)
- At least one Dual Link DVI (for Apple Cinema 30: 2560×1600)
- Two DVI would be better. I wanna send the same picture to two rooms. But this I can achieve with an DVI Dual Link Splitter.
- I want to control the computer from two rooms, both equipped with an Apple Cinema 30
- One room is close to the computer.
- The second room is 30m away.
- I planed to buy a LINDY Fibre Optic DVI-D Dual Link Extender, in order to connect the computer with the 2nd Apple screen, that is 30m away. In theory, this should work, since LINDY says it is Dual Link DVI. But who knows.
Thanks
