A cheap but reliable Wifi USB adapter for Sonoma?
askunk
It seems my Fenvi T919 will be useful only to keep Airdrop (BT) once I install Sonoma.
Can anyone point me to at least one USB Wifi adapter that I can rely on from now on (hopefully, Apple), please?
Thank you!
mariettosun
if you use OCLP you can use your fenvi as its full working order (wifi/BT/Continuity and so on)
askunk
As far as I know, there is only a partial fix for the Wifi. BT works fine.
I can wait, it seems they will eventually fix it. I'll look into the OCLP, thank you.
Any chance you know if BT 5.x is possible? That would allow me to use my AirPods Pro with it. On BT 4.0 they suck badly. :)
Thanks again! :)
