A bit scared of updating to 12.3
askunk
I have successfully updated to OC 0.7.9 (OC Auxillary Tool is amazing!), have enabled SIP and got Sys Prefs asking me to update to 12.3.
However, just as a precaution, I tried to launch the 12.3 full installer from a bootable USB with my working EFI and it got stuck twice during boot. Does this mean I will get stuck during the update, as well?
What should I do if that happens? Will I be able to access the recovery partition and resume the old TM backup? I do not have the 12.2 installer, therefore I am scared I won't be able to install macOS from scratch, in case I need to.
AMD 5900X
Asus TUF Gaming Plus x570 (no wifi)
Asus 6600XT
Fenvi T919
Seagate Firecuda 2TB NvME
tatofuma
AMD 5900X
Asus 6600XT
Fenvi T919
Add this kext to your EFI
askunk
Done. Thank you! I initially forgot to refresh my config.plist :D
The full installer actually starts now, but it leads to the recovery GUI. Not sure whether this is a good sign or not.
I was expecting a macOS installer window, instead I find the typical "restore from backup - reinstall macOS - etc." options window.
Would you suggest me to run the update or am I still at risk that it falls as well into the recovery mode?
askunk
