F20 BIOS
Disabled
Enabled
- Fast Boot
- Secure Boot
- CSM
F11 BIOS is also fine
- Above 4G decoding
- XHCI Hand-off
Hi there,
I have a little question for you Olbo ; In your EFI folder there is a .plist file dedicated to your 5700XT GPU.
Could you tell me how to use it ? Are you supposed to copy it somewhere in your config.plist file ?
Thanks a lot for your help.
Regards, Will.
Thank you for your efforts on this. It works with F20, Im using a rev 1.1 Master an Aorus rx5700XT and all NVMES one with Catalina, one with windows and third as a joint transfer drive with extended FAT. Now I just need to get my Titan ridge to play nicely.
Have you adjusted your bios settings yet ? above 4g etc ... and try taking off XMPThat is Awesome mate....
But I am still can't get it working...
I sent you a mail as it is kinda off topicI enabled the 4g decode and disabled csm...I did even touch XMP profile..Is there any thing I need to change in XMP ?
If So share with me...
Thanks For your response
Try looking at this is for an elite board not a master like oursI enabled the 4g decode and disabled csm...I did even touch XMP profile..Is there any thing I need to change in XMP ?
Hi friends
I have the same MotherBoard. Should I need to switch back to "F11" from "F20" to make the hack work??
I was struggling to boot for days. no Matter what config.plist parameters are change it will stuck at "[EB|#LOG:EXITBS:START] 2020-09-04T09:56:13"
I also tried with Dotaina troubleshooting but no luck. I do not intend to copy paste your EFI . I need help to figure it out happy to do whatever change you suggest.
Now I gonna Startover from scratch and trashing the existing EFI (as recommended to me).
Thanks
RebuildAppleMemoryMap as newer BIOS have trouble with it being set to NO, try enabling it. I also just uploaded a new EFI for OC 0.6.1 which contains various improvementsF20 works, but is inconsistent. I often got graphical glitches and I was unable to boot into safe mode. I've since reverted to F11 BIOS. Since the board contains a switch for the BIOS you can try with both F11 and F20. I think your problem is withRebuildAppleMemoryMapas newer BIOS have trouble with it being set to NO, try enabling it. I also just uploaded a new EFI for OC 0.6.1 which contains various improvements
If none of this works, ensure you enable all logging utilities offered by OpenCore and please paste logs here. You can get the logs fromthe USB drive you attempt to boot from.
I did , I flashed it like on the CMP , it would not boot the system unless a DP was plugged in . It also caused problems in my windows side. So I removed it and put it in my CMP 4.1/5.1 running mojave and opencore 6.1 and it works great . I have a rev 02 Titan ridge coming this week, will try agin , but do not recommend flashing them on a hackingtoshHi have you receive your titan ridge ?
I've upgraded from my original setup to your 0.6.1 and it works really well. However, my FENVI's Bluetooth is no longer recognised by the OS. I'm getting Bluetooth not available in the menubar. I saw that you had various original bluetooth kexts in there that you couldn't upload because of the size limit. However, mine is a native card that works without any kexts. Did you do anything to your config/setup that may interefere with this? I have tried pinpointing the issue, but no luck so far :/
