First hackintosh build and so far everything works on my first attempt!
Edit: I only used the vanilla guide and the recommended outside sources from the vanilla guide. I'm booting from the SSD itself and using the GUI bootloader. I initially started on OpenCore version 0.5.7, but upgraded to version 0.5.8.
Edit 2: I got the WiFi/Bluetooth card in and it was plug-and-play in MacOS! Fenvi has separate Windows 10 drivers for Bluetooth/WiFi which I believe are just the Apple BootCamp drivers, but they work flawlessly. I also upgraded my RAM and case fans (lol) so I updated my build list.
Edit 3: I've compiled my USB-X-DESKTOP SSDT, removed 'AppleMCEReporterDisabler' and 'NVMeFix' kexts, and also updated my MAC address–EFI files updated accordingly (still without 'Resources' files to keep the download size small).
System Build:
OS + OpenCore + SMBIOS:
Works:
Doesn't Work:
Kexts Used:
Drivers Used:
Quirks:
I attached my EFI folder without the Resources folder since it's 95mb. The linked Resources folder goes under EFI > OC which I found under the Add GUI and Boot-chime section of the OpenCore Desktop Guide.
System Build:
- CPU: AMD Ryzen 5 3600
- MOBO: Asus Prime X570-Pro (BIOS v.1407)
- GPU: XFX RX 5700 XT RAW II (Physical switch set to the ‘right’ side)
- RAM: DDR4 G.Skill Ripjaws V 32 GB (4 x 8 GB) DDR4-3600 CL16-19-19-39
- PCI-E Wireless Card: Fenvi FV-HB1200
- SSD1: WD SN750 1 TB M.2 NVMe SSD (Windows 10 Drive)
- SSD2: HP EX950 512 GB NVMe SSD (MacOS Catalina Drive)
- PSU: Corsair RM650x
- Case: Corsair 275R Airflow
- CPU Cooler: be quiet! Dark Rock TF
- Case Fans: (3) Stock + (3) Deep Cool RF120
- macOS Catalina (Version: 10.15.4)
- Windows 10 Education (Version: 1909)
- OpenCore (Version: 0.5.8)
- iMacPro1,1
Works:
- Sleep
- Audio
- DRM (Tested with: Netflix in browser, AppleTV App, iTunes movie purchases)
- iCloud Services (Tested with: iCloud Drive, iCloud Photos, Apple Music, Bookmark/Contacts sync, iCloud Keychain, iMessage Cloud Sync)
- iMessage
- App Store
- Unlocking and R/W external APFS encrypted drive
- Ethernet
- WiFi (Tested with: 5GHz connection to Apple Airport Extreme Gen 5 and Gen 6)
- Bluetooth (i.e. 2nd Gen Magic Keyboard, AirPods, AirPods Pro, Logitech G603)
- Continuity/Handoff
- All USB ports (Both MOBO USB ports as well as my case’s top USB ports)
- Siri
- FaceTime
- AirPlay
- AirDrop
- 165Hz refresh rate
- CPU Power Monitoring/Fan speeds (haven't tested changing clock speeds and don't intend to–But power management seems to be working since clock speeds stay low when idling (<3 GHz) and goes up accordingly when under load)
- Hardware Acceleration
Doesn't Work:
- Line in microphone jack (Apparently a common issue with Ryzentoshes)
- AppleALC doesn't support my MOBO's audio controller's codec (Realtek S1220A) so it's unlikely that my mic jack will work until it is supported. alc-layoutid=1 has the headphone jack working so that's what I'm keeping it set to for now.
- Sidecar (Got it to technically work but it is so laggy that it is realistically unusable)
Kexts Used:
- AppleALC
- Lilu
- SmallTreeIntel82576 (Specific to my MOBO’s LAN chipset)
- VirtualSMC
- WhateverGreen
- AMDRyzenCPUPowerManagement (Needed for AMD power management)
- SMCAMDProcessor (Needed for AMD power management)
- FocusriteUSB2Audio (This is for an external sound card I have that doesn't support Catalina that I eventually got working)
Drivers Used:
- HfsPlus.efi
- OpenCanopy.efi (For bootloader GUI)
- OpenRuntime.efi
Quirks:
- All the guides specifically recommended setting the BIOS boot setting for OS Type to ‘Windows UEFI’ with secure boot on, however my system wouldn’t boot unless OS type was set to ‘Other OS’. My MacOS SSD is set as my boot drive with OpenCore’s bootloader GUI options enabled allowing me to choose either MacOS/Windows 10. SIP is enabled.
- RAM timing/frequency set using the BIOS‘s 3600 CL16 D.O.C.P. preset.
- ‘Power on by PCIE/PCI’ set to ’enabled’ in BIOS
- Couldn’t find the ‘Above 4G Decoding’ BIOS setting so I used the additional boot-arg: npci=0x2000
