The setup:
CPU: Ryzen 7 3700X @ 3.6 GHz
Mother Board: Asus ROG STRIX B550-I GAMING Mini ITX, Wi-Fi card replaced with BCM94360NG
GPU: Gigabyte Radeon RX 5700 XT 8 GB GAMING OC
RAM: Crucial Pro 32GB (2 x 16GB) RAM DDR4-3200
Boot Drive: WD Black SN750 500GB Nvme SSD
My setup and OC configuration work just fine on the latest Big Sur release (11.7.10), and I've been using it for a while. but since a lot of the apps are dropping support for macOS 11 (particularly final cut and adobe CC), I decided to update to Ventura. I made sure to update OC and all my kexts to the latest version too. The installer booted up and worked just fine, but after it booted and begun the setup assistant, the system will panic and shut down in about a minute. When I check the log, every time the error messages look a different than the last (sometimes its about windowserver, sometimes finder, and other times about APFS/AMD drivers, etc) Here's all the stuff I tried so far:
On another note, when Monterey came out, I attempted installing it on my setup and it had similar problem (booting in the login screen just fine but crashes in a minute or so)
Here's a screenshot of the EFI folder and the newest kernel panic log. I've been troubleshooting this for days but have yet made any progress. Any help would be greatly appreciated!
EDIT 1: Uploaded the entire EFI folder as requested
- Getting a new SSD. I used to have a samsung 970evo, but since it doesn't particularly play well w/ macOS due to the TRIM implementation, so I bought one from WD instead
- Resetting BIOS
- memtest (passed twice without issues)
- Wiping everything and perfoming a clean install
- Mapping USB ports using USBToolBox
