Atari VCS native on Mojave 10.14.6
43
Atari VCS
AMD Ryzen 1606G CPU w/ Vega 3 (Picasso)
Ridge Raven 2
32GB DDR4 RAM
500GB WD Blue M.2 SATA SSD
Sandisk 16GB USB
Took me a while to figure it out, but here it is! The Atari VCS running Mojave 10.14.6 natively.
You can find my guide over at the Tonymacx86 website
Ok, just thought to update you guys on some successes I've been having of late.
I'd upgraded my VCS to Big Sur 11.3.1 and it seems to have gone through very smooth.
In addition, I'd been tinkering with some of the devices and kexts in my build on High Sierra and I have almost achieved hardware acceleration on my
build (as an APU based unit). I've managed to enable DRM to play videos, the onboard AMD HDMI and audio processor as well as unsupported SATA.
Wow! Awesome stuff dude! That's some really innovative stuff here! Maybe some of the devs and Hackintosh gurus can take notice of the APU progress you've made!
This is a nifty idea. Good job!
Reactions: Middleman
Thanks!
To setup and boot into the system firsthand, I used Mojave, and the key point was that aside from obviously using an AMD-compatible Opencore build (with the new AMD kernels) I disabled HPET in BIOS and used a SSDT-GFX0.aml and the shikigva=40 and shiki-id=Mac-7BA5B2D9E42DDD94 to boot in with SMBIOS iMac19,1 because my system was a Vega 3 graphics. That's what allowed me to install Mojave, then move on to Big Sur. But BS doesn't allow Shiki boot-args so you have use a different SSDT or AGPMInject kext instead.
Reactions: agent2
Good stuff!
Thanks for the info!
If it helps this is what used also for my setup:
Kextstat audio results. No pin setup yet, but close!
Btw I also found this. I believe Shanee might be interested in this. It's the CPUID for my Ryzen 1606G!
I'm a big fan of this project, do you still use it middleman?.
I see! As for usage, not so much now since I upgraded my Acer Nitro 5 to Monterey.
