Unable to upgrade from 11.2.3 to 11.3
soulblood
24
Hi guys, im running oc 0.6.8 w/ 11.2.3. OS is running smooth, everything working fine. But im unable to update to 11.3 as I always stuck at [EB]#LOG:EXITBS:START]
I have 3600+b450i. And EFI is attached. Thanks advance for all the help.
Seems it couldn't find kernel 17 but I don't really understand why it was fine when im running 11.2.3 or older 11.x....
  • EFI 068.zip
    EFI 068.zip
The patch has changed to accommodate the new kernel.
Apply the latest available patch
for some reason I had to reset nvram 5 times to get this new kernel patched.....but its working now. Thanks for the info
Could you post your new EFI? Having troubles with the patch and would like to compare.
