Sudden slowness
silvergraphs
9
Buenos Aires, Argentina
Ryzen 7 5700X
I notice that my system works well, but on certain occasions it starts to jerk, and after a few seconds it returns to normal, for example sometimes I am listening to music and programming in Visual Studio Code and suddenly everything slows down, the music , it starts to lag, the cursor, and after a few seconds it stabilizes again, (only on 2 occasions it happened to me that the music slowed down so much and it got so stuck that it never played again, I had to wait about 3 or 4 seconds to normalize and pause and play music again) maybe it is that the CPU/GPU speed drops for some reason? I haven't checked it yet, what do you think it could be? I rule out temperature problems because I assure that I have them well controlled, the hardware is also all new
I had audio dropouts (external Focusrite over usb) when I used Photos or simply wrote and e-mail and did copy and paste actions. They went away when I went into the bios and set my graphics card pci slot to Gen3 (from Auto/Gen4). No guarantees but at least free to try!
Reactions: silvergraphs
Thank you, i will to test it.
Check your BIOS for Serial/Parallel port and make sure it's diabled.
Reactions: Red Pfeffer
I had the same issue with my other build. Ryzen 7 3700X with MSI Gaming Plus B450. The Serial/Parallel port already disabled. I suspected that my NVME SSD is the culprit.
I did what you told me, that fixes the problem that the mouse starts to freeze and that while the music was playing, it jammes, I have not experienced it again, but there are still unexpected restarts. The mouse freezes for a few seconds, then the screen and the keyboard and mouse lights go off, there is a noise from the fan as if the speed of the fan rises and falls and thus remains infinitely unless you press the reset button. The fan noise I estimate is that of the GPU since I have a CPU Fan that does not reach more than 800 RPM, it is limited (it does not make noise, I know the noise of it so that's why I discard it, And my other fans are only connected by electricity, without PWM) so I also discard them. I do not have temperature problems in CPU. Checked from Windows. Talking about the GPU, in Windows with FurMark 720p 4x MSAA it reaches 72C max. I don't think it's a problem, it's an AsRock RX 570 and they are usually hot. What could be causing these problems on macOS? Regards.
@silvergraphs Do you have the DummyPowerManagement quirk enabled?
