Kernel Panic
MartoBTW
Please list your systems specs and attach an image of the kernel panic.
What kexts are you using?
@MartoBTW Seems ok there. Can you zip and upload your EFI folder.
Try with this,
Hi,
I am having the same exact panic(CPU X Caller issue and cannot find a solution anywhere. I followed the same guide and I have also checked my config.plist with the sanity checker as well and everything seems to be in order, but I must be missing something. I have attached my EFI in a zip. Wondering if we have a common issue, or if I just missed something. Any help is appreciated!
I am on an MSI B550 with Ryzen 3600 + RX 580
Thanks!
Edit: my EFI folder is about 28MB where it says yours are both around 2MB so it won't let me upload. Could you tell me what the attempted fix was? I will have to figure out why one of my Intel kext is so large
Why is your EFI folder so large?
what kexts do you have in there?
If you are using open canopy then delete all the audio from the audio folder in resources and if you using the openintelWiFi and Bluetooth kexts then remove them too and send over your EFI.
I have attached the EFI minus IntelBluetoothFirmware.kext and Airportitlwm.kext. I also had nvmefix.kext at one point but read that could cause an issue so I removed the kext and removed it from the config.plist but the same panic remains.
Also, I realized I said it's an MSI board before, but its actually an ASRock B550AM Gaming. I've been looking for an older MacPro to upgrade, but I picked up a pre-built CyberpowerPC for $400 just 2 days ago and thought it would be a great fit! Couldn't believe the deal, I wouldn't be able to find this price even before the GPU and Silicon shortage! It's only 6 months old and been used for about half that time. The guy said his son bought it last year and then decided to build one himself.
Hwinfo reports the board as an MSI for some reason, so I noticed after looking at the mobo that it's an ASRock. It also reports the RX580 as an XFX but it's an HIS, gpu-z also reports the card as XFX so I'm assuming the board I'd must be the same.
@AudioGod any luck? I'm still struggling with this. I'm new to this site and also wondering if it notifies when someone comments on the thread after you because I never got notifications about your comment after I posted.
Try.
