Solved I've lost sound onBigsur beta 11.3
Pehem17260
It's possibly an incompatibility with VoodooHDA on the latest beta. Are you on the latest kext version?
Pehem17260
it's a 2.96 !
Is it being loaded? Run this in Terminal,
Bash:
kextstat | grep -v com.apple
Pehem17260
Executing: /usr/bin/kmutil showloaded
No variant specified, falling back to release
Index Refs Address Size Wired Name (Version) UUID <Linked Against>
49 2 0 0x2c000 0x2c000 as.vit9696.Lilu (1.5.1) 60B5CEA5-DAA5-3889-8EF9-7DAEF72290DA <8 6 5 3 2 1>
50 0 0 0x7c000 0x7c000 as.vit9696.WhateverGreen (1.4.7) 2748A9DA-DFFE-3134-B8EB-B643C5BEC029 <49 14 8 6 5 3 2 1>
60 0 0 0x19000 0x19000 as.vit9696.VirtualSMC (1.2.0) 985765C2-4A4C-3B6F-BA8F-E7FC032B441E <49 13 8 6 5 3 2 1>
68 0 0 0x85000 0x85000 com.insanelymac.RealtekRTL8111 (2.4.0) 6A37A018-F508-3263-BF10-3233125A1666 <47 14 6 5 3 1>
Voodoo HDA don't load !
Pehem17260
It seems to be related to SIP after looking at the VoodooHDA topic on InsanelyMac, https://www.insanelymac.com/forum/topic/314406-voodoohda-296/?do=findComment&comment=2740175
Slice then later states
This is for 2.9.6 but that's what you have. Not sure if he fixed the SIP issue.
I've changed the voodoohda nothing change. How can make a diagnostic to send on discord channel .?
Did you disable SIP?
Pehem17260
Yes
in my config.plist
csr-active-config <FF0F0000>
Is it correct? I look dortania guide
Yes you need to add it in Delete also,
NVRAM -> Delete -> 7C436110-AB2A-4BBB-A880-FE41995C9F82 -> csr-active-config
Pehem17260
Ihve the twice but I've a new message at boot OpenCore
  • 20210305_121714.pdf
Pehem17260
Hello; a new question. i resolved partially my sound problem. I've made a new clean install. But all kext are loaded (VoodooHDA included). After the connection sound load one second and it crashed. What sort of infos do you need for help. Sound are ok under ubuntu and windows.
Last login: Sat Mar 20 10:27:13 on console
pascal@iMac ~ % kextstat | grep -v com.apple
49 2 0 0x2c000 0x2c000 as.vit9696.Lilu (1.5.2) C49B8989-F514-3446-9712-95AD05CED350 <8 6 5 3 2 1>
50 0 0 0x7c000 0x7c000 as.vit9696.WhateverGreen (1.4.9) 118038D2-FAEB-3542-A6C7-9C20123C6FBC <49 14 8 6 5 3 2 1>
59 0 0 0x19000 0x19000 as.vit9696.VirtualSMC (1.2.1) 674E05D8-56CE-3DBF-AC41-5CA30040F72A <49 13 8 6 5 3 2 1>
70 0 0 0x40000 0x40000 org.voodoo.driver.VoodooHDA (2.9.6) 53BCAB07-B189-3F43-AB15-28C700D84B49 <69 14 8 6 5 3>
77 0 0 0x85000 0x85000 com.insanelymac.RealtekRTL8111 (2.4.0) 6A37A018-F508-3263-BF10-3233125A1666 <47 14 6 5 3 1>
batchi21
Is RX6800XT supported in 11.3?
Please let me know if you know.
Zhenxin
我安装上了Bigsur,用的USB声卡,但是不能输出音频,在播放音频的前一秒崩溃
Zhenxin
Have you solved it
