Shaneee's RyzenPro - 5600X, RX 480
First post updated. New CPU, GPU and updated GeekBench scores :D
Not bad, but only the Metal score is getting close to thread ripper 3970x / Radeon Vii :-)
Any more news regarding speeding up fps in general for Steam games etc?
Not bad, but only the Metal score is getting close to thread ripper 3970x / Radeon Vii :)
Just the updated PAT patch enabling better frames on AMD GPUs.
Hi Shaneee, now i have more time, to fine tuning my ryzentosh. Since the begining i didn't use the 2,5g ethernet on my system. I have installed the Lucy RTL8125 kext and found through W10 filled the IP adress, it show me a green led "connected" but i can not have a web connection working. would you please make short tuto about it please ?
DHCP with manual address? What if it's on auto DHCP? Failing that you may need to run this in Terminal,
Bash:
ifconfig en0 media 1000baseT
Reactions: AMDPUSH
Bash:
thanks for your answer
1/ Location --> Automatic
2/ if i am using DHCP there is no info showing up
3/ then i go to Manuel, i filled the fields, the green led says connected, but i can't see any DSN server and search domain
4/ i went to advanced setting --hardware Manually 100baseT full duplex custom 1500
Tried connect to internet nothing.
At which moment i have to run the terminal command ?
Might be worth creating an issue on the GitHub for the kext then.
Reactions: AMDPUSH
Hi, glad to see that ,now LucyRTL8125Ethernet.kext work nicely in OC 067 !
Reactions: Shaneee
