Luminar ai
The following commands did it for me. Luminar AI is starting and working great so far.
First I ran the this command
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x6A\x00|\x90\x90\x90\x90\x56\xE8\x3A\x00|sg' '/Applications/Luminar AI.app/Contents/Frameworks/MPCore.framework/Versions/A/Frameworks/libtbb.dylib'
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x4A\x00|\x90\x90\x90\x90\x56\xE8\x1A\x00|sg' '/Applications/Luminar AI.app/Contents/Frameworks/MPCore.framework/Versions/A/Frameworks/libtbb.dylib'
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x6A\x00|\x90\x90\x90\x90\x56\xE8\x3A\x00|sg' '/Applications/Luminar AI.app/Contents/Frameworks/MPCore.framework/Versions/A/Frameworks/libtbbmalloc.dylib'
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x4A\x00|\x90\x90\x90\x90\x56\xE8\x1A\x00|sg' '/Applications/Luminar AI.app/Contents/Frameworks/MPCore.framework/Versions/A/Frameworks/libtbbmalloc.dylib'
and then
sudo codesign --remove-signature /Applications/Luminar\ AI.app/
Maybe the first 4 lines aren't even necessary. I've not tested without them. But the second command was mandatory!
Reactions: genny68 and Heiko77
for me too.
What is the latest version of Photoshop that works with Big Sur? Thanks in advance.
Reactions: xoa
and then
Works like charm ... Thanks
Reactions: sunsunich and xoa
Luminar Neo c'e qualche patch?
This worked for me:
Bash:
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x6A\x00|\x90\x90\x90\x90\x56\xE8\x3A\x00|sg' '/Applications/Luminar Neo.app/Contents/Frameworks/SLFoundation.framework/Versions/A/Frameworks/libtbb.dylib'
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x4A\x00|\x90\x90\x90\x90\x56\xE8\x1A\x00|sg' '/Applications/Luminar Neo.app/Contents/Frameworks/SLFoundation.framework/Versions/A/Frameworks/libtbb.dylib'
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x6A\x00|\x90\x90\x90\x90\x56\xE8\x3A\x00|sg' '/Applications/Luminar Neo.app/Contents/Frameworks/SLFoundation.framework/Versions/A/Frameworks/libtbbmalloc.dylib'
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x4A\x00|\x90\x90\x90\x90\x56\xE8\x1A\x00|sg' '/Applications/Luminar Neo.app/Contents/Frameworks/SLFoundation.framework/Versions/A/Frameworks/libtbbmalloc.dylib'
