First time install ASROCK X570m PRO4 Ryzen 7 2700x Not working
racerblur
First time install ASROCK X570m PRO4 Ryzen 7 2700x, 32gb ram and 5700XT
- I tried several time to make a boot-able USB installer, but OCS: No Schema for Protocols at 5 index!
and OC: Configuration requires vault but no vault provided!
I have not idea what to do. I looked at all the different build related to by motherboard, but nothing seems to boot.
I'm new to AMD OS hack Ryzen installs, and I know the pains of getting things to run right on the Intel side,
but at least I can get installer to boot.
Any ideas... I've tried everything...
Your config.plist has some errors, that's what OC is complaining. You can check it here: https://opencore.slowgeek.com
The second issue: Under Security set Vault to 'Optional'.
racerblur
I'm getting these errors..
UEFI - APFS section is missing  UEFI - ProtocolOverrides section is missing  UEFI - ReservedMemory section is missing
I can't find any information on them....
Thanks for all you help thus far!
Mishaxxx
text my i will send you a working config efi folder
Your config is missing sections from the UEFI area. Compare yours to the Sample.plist
They should have already been there but seems you've managed to remove them.
