Specs:
Processor: Ryzen 9 3900X
Motherboard: X570 TUF Gaming-Plus (WIFI)
GPU (Top Slot): ASUS Dual RX580 (Hackintosh)
GPU (Bottom Slot): TUF Gaming RTX 3070 (Windows)
RAM: TForce TUF 16gbx2 3600mHz
Storage 1: 1TB Samsung 970 Evo Plus (Windows)
Storage 2: 500GB Samsung 970 Evo Plus (Hackintosh)
Primary Monitor: AOC Q27G2S
Secondary Monitor: AOC 27G2
OpenCore version: 0.6.4
Not Working:
Audio Jacks
Problem:
So my setup is a dual boot, dual GPU, dual monitor setup. I think this is not really a Hackintosh problem but there might be people who encountered this?
My RX580 uses HDMI ports, then the 3070 uses DisplayPorts. The monitors are set to "Auto Detect". The Secondary monitor always receives the signal on boot first (contains the BIOS stuff) then the Primary monitor just says "DP" but it's blank.
When I boot into Windows, the Secondary monitor is stuck on HDMI which shows the BIOS logo stuff, then the Primary monitor shows Windows.
When I boot into macOS, the boot verbose stuff shows in the Secondary monitor, but the Primary monitor is stuck on DP which shows blank.
So when booting either OS, I have to manually switch the monitor to the correct output. There might be a solution for this, I just don't know what or how so I'm asking for help.
Also, about the audio jacks, the audio itself is working. I have Bluetooth earphones connected and are working fine. But I can't really understand how I can make the jacks work.
Not Working:
Audio Jacks
Problem:
