MSI MPG B550 GAMING EDGE WIFI - Radeon RX 5600XT - Ryzen 5 3600 - iMacPro1,1 - OC 0.6.4 - Big Sur 11.1
tdubbs
23
My first Hackintosh! Currently dual booting with Windows 10 Pro.
Specs -
CPU - AMD Ryzen 5 3600 3.6 GHz 6-Core Processor
Motherboard - MSI MPG B550 GAMING EDGE WIFI ATX AM4 Motherboard (https://www.msi.com/Motherboard/MPG-B550-GAMING-EDGE-WIFI/Specification)
Memory - Team T-FORCE VULCAN Z 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory
Storage - Mushkin Pilot-E 2 TB M.2-2280 NVME Solid State Drive ( Seagate SSHD temporarily)
Video Card - Gigabyte Radeon RX 5600 XT 6 GB GAMING OC Video Card
Case - Fractal Design Meshify C ATX Mid Tower Case
Power Supply - Thermaltake Toughpower GF1 PE 750 W 80+ Gold Certified Fully Modular ATX Power Supply
Currently running OpenCore 0.6.4 with Big Sur 11.1
Kexts-
AirportItlwm.kext
itlwm.kext
AMDRyzenCPUPowerManagement.kext
LucyRTL8125Ethernet.kext
WhateverGreen.kext
AppleALC.kext
SMCAMDProcessor.kext
Lilu.kext
VirtualSMC.kext
ACPI-
SSDT-CPUR.aml
SSDT-EC-USBX-DESKTOP.aml
What works-
Audio - RealTek ALCS1200A - Modified AppleALC.kext (See post below)
Ethernet -Realtek RTL8125B - Needed to be configured with Manually with 1000baseT in Full-Duplex. Auto negotiate does not work.
Wifi Intel Wi-Fi 6 AX200 (Using itlwm - https://openintelwireless.github.io/itlwm/Compat.html#gen-1)
USB 3.0 & 2.0
Bluetooth
iCloud
iMessages
Facetime
Sleep & Wake
Sleep and Shutdown via the Power Button
Netflix
What does not work-
SideCar
AirDrop
Notes-
Needed to disable SecureBoot
Boot Args - -v keepsyms=1 debug=0x100 alcid=1 npci=0x2000 agdpmod=pikera
Screenshots -
Reactions: AudioGod
For your audio problems see here on how to fix it.
You should also consider mapping your USB properly cos looking at your hackintool screenshot with your layout it’s listing nearly all your ports wrong.
Much appreciated I'll check it out. I've been using my USB 3 Hub on my monitor, didn't realize the others weren't working. I'll look into mapping.
Use this handy little tool to do your mapping with.
makes it as easy as doing it on a Intel build, :)
I've tried many different combinations with no luck. Output devices are listed, all I hear is static. I'm currently using audio via my monitor with headphone out to my speakers. I have a thread open on my issue - https://forum.amd-osx.com/index.php?threads/alcs1200a-big-sur-no-audio-static.1419/
UPDATE - Audio is working!!!! Still need cleanup in step 4 & 5. It's showing as Line Out in prefs. THANK YOU!
Config Data is- (Still needs mapping with pin configurator)
<01471C10 01471D50 01471E01 01471F01 01470C02 01671C11 01671D10 01671E01 01671F01 01571C12 01571D10 01571E01 01571F01 01B71C20 01B71D40 01B71E21 01B71F02 01B70C02 01E71C30 01E71D11 01E71E45 01E71F01 01171C40 01171DC5 01171E37 01171F40 01871C40 01871D10 01871EA1 01871F01 01A71C4F 01A71D10 01A71E81 01A71F01 01971C50 01971D90 01971EA1 01971F02 01771CF0 01771D11 01771E11 01771F41>
Make sure to match alcid=1 in boot args, and change the layout id to 1 in Info.plist so it loads the correct device.
Reactions: AudioGod
Hi man! I'm on your same MB and as you this is my first Hackintosh!
do you say your Bluetooth worked for me, with the last version of itlwm everything works (wifi/Bluetooth) but I can't turn off the Bluetooth or connect to any device, do you got any problem like that?
thank you
EDIT:
My board is the same i installed sucessfully. My audio is working as i use focusrite solo 2 device. For Me bluetooth is working but not wifi though wifi showing in task bar but not displaying any network , In network settings its showing eth 2 Like ethernet card not wifi .Gowever hacktools shows Ax200 in pcie. Iam using the same ktexts and tried different combination but no luck.
Before bigsur i insrtalled catalina where issue was same atleast in bigsur its showing wifi symbol in taskbar .I updated bigsur from catilina using recovery without format the drive
can anyone help regarding wifi
