Big Sur and AMD FX
Pehem17260
7
Big applause for Shanee with the new patch for BulldozerCapture d’écran 2020-11-21 à 10.41.00.png
Reactions: ozupi and laurent
can you please share your EFI Folder bro?
Reactions: laurent
Thank you bro, you have no problem with the app store, crashes or something?
for all is ok
Is this using the experimental branch for 15h_16h?
yes
it' works fine
with OC 0.64 I've a message about 10.16 al grey patch
Hi Shannee
i sent picture of message
it's seem a kernel patcher
while Ive had success with a Msi b450 VDH max Ryzen 5 1600 with a R9 380 0n Catalina I can't seem to get this one to work at all. I think my motherboard isn't going to work.
Here is my HW info.
AMD FX-6300
GA-78LMT-USB 3 R2
AMD Radeon R9 380
Realtek® ALC892 codec
Realtek® GbE LAN chip (10/100/1000 Mbit)
