OpenCore ver 0.7.4 · BigSur 11.6
Update, Oct 5th 2021: GitHub repo has updated hardware list and current EFI.
Original post, Dec 5th, 2020:
Current hardware, pretty much upgrade to my earlier build using R5 3600.
This all works great and silent with this AIO, with max CPU temps around 80°C when all 12 cores are fully loaded.
The combo below offers natively supported WiFi 5 / Bluetooth 4.
Combined with this riser cable, the card/adapter combo from above can be moved outside the motherboard I/O shroud, instead of existing Intel AX200 card.
- Mini PCIe riser with adapter for M.2 Key A/E
Version 2.71
Pretty much everything.
- AMD Ryzen 9 5900X CPU
- XPG Levante 240 AIO
- ASRock X570 Phantom Gaming-ITX/TB3 motherboard
- Sapphire Pulse RX 5500 XT SF 8GB graphics card
- Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4 3200MHz CL16
- Corsair SF600 Platinum SFX PSU
- Noctua NF-A12x25 case fan
- ADATA XPG 8200 Pro 1TB NVMe SSD
- Samsung 860 EVO 500 GB 2.5in SSD
- Nouvolo Steck v1.1 SFF case at the moment.
WiFi / Bt
- 1750Mbps Dual Band WiFi 2.4GHz/5GHz / Bluetooth 4.0 Broadcom BCM94360CD card
- mini PCIe adapter card
BIOS
Version 2.71
- Fast Boot: Disabled
- CSM: Disabled
- Above 4G Decoding: Enabled
- PCIe speed: Gen 3 (do not leave it on Auto)
- XMP Profile set and running.
What’s working
- NVMe SSD recognised properly.
- WiFi, Bluetooth, Ethernet
- All USB ports properly mapped. Steck case does not have any ports thus internal USB header is not connected.
- Radeon GPU, natively supported.
- All media services (Plex, Netflix in Safari, iTunes, Apple TV+ etc). All are fully hardware-accelerated.
- 4K HDMI with HDR, Dolby.
- Watch unlock, Handoff, iMessage, iCloud, Keychain, Xcode etc.
- System Integrity Protection (SIP) fully enabled.
What’s not working
- Sidecar
- Sleep / wake
- Thunderbolt 3
