What about the cpu name ?
kwankiu
As i remember there were some post about this on the old forum, but i am unable to find a post about this here, so i would like to ask that :
After we installed our ryzentosh, the cpu is displayed as Intel Core i5 on the About this Mac page, so what's the latest method to modify this on Big Sur?
Thanks everybody, got the solution :
  1. Disable FileVault
  2. Reboot into recovery mode
  3. Go to terminal (in recovery mode)
  4. Run csrutil disable
  5. Then run csrutil authenticated-root disable
  6. Reboot back into MacOS and start up a terminal
  7. Find your root mount's device - run mount and chop off the last s, e.g. if your root is /dev/disk1s2s3, mark down /dev/disk1s2
  8. Create a new directory, for example mkdir ~/mount
  9. Run sudo mount -o nobrowse -t apfs DISK_PATH ~/mount , DISK_PATH is the value you marked down in Step 7
  10. Run cp /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/Resources/en.lproj/Processors.strings ~/Desktop/
  11. Now the file "Processors.strings" is ready in our desktop for modifications, open it with BBEdit
  12. For example my about this mac shows 6-Core Intel Core i5, you should see something like this : <string>6-Core Intel Core i5</string><key>6-Core Intel Core i5</key>
  13. Replace it with <key>6-Core Intel Core i5</key>
    <string>6-Core AMD Ryzen 5</string>, you may also use other name you want instead of "6-Core AMD Ryzen 5"
  14. Now save and close BBEdit
  15. Run sudo cp -Rf ~/Desktop/Processors.strings ~/mount/System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/Resources/en.lproj/
  16. Note if your region isn't US, you may need to one more thing : Go to About this Mac -> System Report -> Language & Region, pick up the first few language in "OS Interface Languages" until it works.
  17. For example, I got OS Interface Languages: en, en-GB, en-AU, en-IN, zh-Hans, zh-Hant, zh-HK, ja, es, es-419, fr, fr-CA, de, ru, pt-BR, pt-PT, it, ko, tr, nl, ar, th, sv, da, vi, nb, pl, fi, id, he, el, ro, hu, cs, ca, sk, uk, hr, ms, hi, i picked up the first three. So after i did Step 10, i replaced "en.lproj" with "en_GB.lproj" then run Step 10, now with "en_AU.lproj", run step 10 again. cp /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/Resources/en_GB.lproj/Processors.strings ~/Desktop/ cp /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/Resources/en_AU.lproj/Processors.strings ~/Desktop/
  18. Run sudo bless --folder ~/mount/System/Library/CoreServices --bootefi --create-snapshot
  19. Reboot your system, and the changes should take place.
zeph016
Here is the old post that you meant which was for catalina >Click Here< . Which does not work on Big Sur.
From what I understood so far:
On Big Sur it's kind of tedious because we aren't really booting from the install disk but from the "Snapshot" of the disk.
The main install disk is readonly so the command "sudo mount -uw /" won't work. Modifications to System(install disk) steps are new on Big Sur.
Although I managed to change mine successfully. I'll post the steps if want to know how.
Jesinth
Please tell the steps to change to writable in big sur
kwankiu
oh yeah that link is my previous post for catalina, so the place to change cpu name is same, just that we have to solve the read only issue ?
zeph016
I won't be able to make a guide right now because I'm traveling but this is the guide i followed in order to make changes to the main disk by mac_editor: >Click Here<
Refer to the "Bypassing SSV" portion.
After mounting the disk and volume you can modify the system or in this case change the CPU name.
Don't forget to create a snapshot and tag the snapshot to be booted. Also indicated on mac_editors' guide.
Just be aware that you have to leave authenticated root disabled, if activated again macOS will fail to boot after you modified the root volume.
kwankiu
  13. Replace it with <key>6-Core Intel Core i5</key> <string>6-Core AMD Ryzen 5</string>, you may also use other name you want instead of "6-Core AMD Ryzen 5"
@kwankiu After modifying the CPU name you can reboot into recovery mode and re-enable SIP csrutil enable (but not authenticated root).
x-c0d3
it's worked on my AMD Hackintosh (big sure 11.0.1)
but cannot enable SIP mode after creating a snapshot
if re-enable SIP back again I am found a problem cannot boot to macOS
tung_opeth
i cant get pass the step 7, do u know why?
x-c0d3
tung_opeth
x-c0d3
hi , thanks for respond, but now i got this
make sure "authenticated-root" disabled?
check the status with this command
sudo csrutil authenticated-root status
you can disable authentication root with opencore config
<key>csr-active-config</key>
<data>dwgAAA==</data>
tung_opeth
yes i pretty sure i did disable those
tung_opeth
i managed to run the code below
  1. Run sudo bless --folder ~/mount/System/Library/CoreServices --bootefi --create-snapshot
but yet still the cpu name is not changed
i even changed the strings for all the languages i found in
does anyone knows how to fix?
@tung_opeth depends on what CPU is shown by default. If "Unknown" or an Intel you will have to replace different keys in different files: AppleSystemInfo.strings for Unknown and Processors.strings for Intel CPU.
tung_opeth
i edited the .strings by sublime text thats' why things messed up, works fine now
