Hi there !
I try to install BigSur on this configuration :
CPU: 3900X
MOBO : X570 AORUS PRO WIFI
Graphic : rx5700XT EVOKE OC
RAM: 32gb 3200 corsair platinum
SSD: 512 970 EVO PRO NVME
I successfully installed Catalina in the beginning of the year, but i reinstall windows for some reason, and, because im dumb, i totally forgot to save my EFI folder ..
So, i plan to install BigSur , unfortunately i have had problem when i boot :
I dont see Install Mac OS Big Sur ( external drive) only EFI (external drive)
When i boot into it there is a bunch of error ( See Attached )
There is a link to my EFI folder too : https://mega.nz/file/ussUlAwT#cuKJCX65fmmTuN4jamolefUN3no8A34qyGC8YtOOVVU
If you can help !
I dont have any way to get out of it , hope you can help me !
CPU: 3900X
If you can help !
