Hackintosh Installation
RemoveKebab
Hi, my specs are:
Ryzen 5 3600X
MSI B450M PRO-M2 (non-MAX, had 2gen Ryzen before)
16GB-3000
GTX 1060 3GB
I have no problem with High Sierra but im aware that I need and AMD gpu to run Mojave, Catalina or Big Sur but is there a workaround for pascal cards like mine? Thanks.
There's no macOS support for turing cards I'm afraid.
High Sierra for Pascal only
RemoveKebab
Misread it as 1660 sorry. High Sierra is the highest supported version for your setup then.
Okay I get it. I need help to install it again because last time I could not plug anything on it except the mouse and keyboard. I have no ethernet in my room so I used a laptop I had to connect an ethernet cable. I also used my wifi stick and still didnt work. Also my phone for tethering didnt work. I installed android drivers for mac and didn't work.
EDIT: For those who are conserned, yes it was High Sierra.
Sent from my MI 8 Lite using Tapatalk
