Big Sur 11.0.1 | Asus STRIX b550-i | Ryzen 3600 | OC 0.6.0 (works too for Mojave 10.14.7/Catalina 10.15.7)
Hi clinthaus
Sorry, I didn’t see you write something.
You installed Big Sur on your B550-I !
I have big problems during installation...
I have an error « disk is write locked » and it stop the verbose and it continues. And after the first screen of macOS installer, after rebooting, I have a boot loop...
for the sound, I have no problem with the last appleALC with alcid=7
Hi @manoueltiger !!
Just ended fixing last problems of audio with Big Sur.
Now works perfect!!!!!!
The problem with the audio was my new AMD 5800X...
Yesterday a new pach was appeared to upgrade the new 5000 amd series (opencore 0.6.4) and now is perfect.
About your error with the disk... sorry but I cant help you. I´m a begginer on Hackintosh 😅
If you need my EFI feel free to ask.
Reactions: manoueltiger
Hi @manoueltiger !!
Yes can you give me your efi please ? :)
Yes don’t worry ! Many thanks !
edit :
it’s incredible !!
I have the same error « disk6: device is write locked » and i can’t install big sur even with this EFI ...
did you change something in your bios
edit :
it’s incredible !!
changes I did on my bios (I think we have the same bios) My bios is with the last update.
first load bios defaults
Disable
Fast Boot
Secure Boot
Compatibility Support Module (CSM) off
Enable
Above 4G decoding(This must be on, if you can't find the option then add npci=0x2000 to boot-args. Do not have both this option and npci enabled at the same time)
EHCI/XHCI Hand-off
OS type: other system (not windows uefi)
I put pcie ports on gen 3
Big Sur is installed on one empty disk
did you format your disk correctly?
hope it helps!!!
I made everything you made.
I finally succeded but now my system freezes when I come on my desktop...
Edit :
I finally install big sure but I have a KP with appleintelpowermanagement ... 1mn after logging in...
Edit :
did you use my config.plist?
send me your rebuilt EFI to check if you missed something
I use the same EFI
Except I put airportbrcmfixup inside
Hi @manoueltiger
Seems people have issues with airportbrcmfixup and KP...
I think the only thing is different about our pc´s is the GPU and the CPU
Try to read the manual of dortania step by step configuring your config.plist
Maybe is something wrong
Hi @manoueltiger !!
Hey, can you please share your EFI folder ?
seriously clinthaus... I'm tired.
I thought I found the error but now I probably broken everything And it gets me mad.
I DON'T UNDERSTAND why it's so hard to update my hack and why you succeeded to install bigsur...
I used your EFI, verify my bios, etc... turn off wifi and ethernet and now I have a log:exitbs:start error everytime I try to boot on my USB key...
It's totally meaningless
dont give up!
did you check here?
ok guys.
Thanks to clinthaus, I finnaly had a success install...
I think intel LAN controller is messing with macOS, so I disabled it in BIOS.
I updated the BIOS.
I disabled before installing macOS the wifi and tadaaaaaa. I have big sur 11.0.1.
It was so hard to update my computer, it's incredible.
Now I cross fingers to have problem in the future...
Reactions: clinthaus
ok guys.
I updated the BIOS.
enjoy your new hackintosh!! now is time to put your efi folder in a save place for a backup!! :)
Motherboard-- Asus ROG STRIX B550-F GAMING ( non Wifi ) Bios version 1202 OC 0.6.3
CPU-- 3700X
GPU-- RX580
SSD-- Sabrent Rocket NVMe 4.0 (1TB)
I have Big Sur version 11.0.1 (20B29) install
Problem 1: Is there a special kext to get the Lan working? I have LucyRTL8125eEthernet.kext installed its not working
Problem 2: The system is not stable Constant random reboot. It happens while the system is booting up, while typing my password at the login screen very random.
Any suggestions on how to fix these issues ?
Motherboards-- Asus ROG STRIX B550-F GAMING ( non Wifi ) Bios version 1202 OC 0.6.3
CPU-- 3700X
GPU-- RX580
What kext are you using ? :)
clinthaus use other kexts But I don’t remember which kext !
a clinthaus : yes thanks dude, you helped much than people on discord !
