Success - Catalina 10.15.7 - AMD FX 8350 - ASUS M5A99XF PRO r2.0
a6666
21
CPU: AMD FX 8350
GPU: AMD RX 580 8gb
RAM: 16 gb ddr3
Motherboard/Laptop Make and Model: Asus M5A99FX PRO R2.0
Audio Codec: ALC892
Ethernet: Realtek® 8111F
Wifi: i don't use wifi.
I have been using it as the main operating system for 1 month. The only problem I had was with a library (libvDSP.dylib) but after changing it for an old version everything works correctly. (fix in my post here -> https://forum.amd-osx.com/index.php?threads/cleanmymacx-crash.1071/ )
wallpaper: https://images.app.goo.gl/TU93JhTHk2SVsLqz5
Reactions: Joanmatias15
CPU: AMD FX 8350
GPU: AMD RX 580 8gb
RAM: 16 gb ddr3
Audio Codec: ALC892
Bro can you share your efi folder please?
Thank you so much brother, what version of OpenCore did you use?
