[SOLVED] Weird artifacts when installer loads with B550 board
rohowsky
Hi guys! I just built a new PC to start with my first ryzentosh, but I am having some issues. I am a beginner and at the moment I just managed to make work a highly compatible configuration like the HP 8300 both with Clover and Opencore. My new configuration has the following components:
Mainboard Gigabyte B550M DS3H
CPU Ryzen 3 3100
GPU RX460
RAM G.Skill 2x8Gb 3200
I set up Opencore by following the guide by Cortania. The installer loads but it shows weird artifacts, like in the picture I posted. Any idea what the problem might be?
In the link, you can also find my EFI folder and my config.plist file.
EFI folder
RyzeCooker
Add agdpmod=pikera in your boot arguments to see if it helps.
Update to the latest BIOS revision. It seems to be related to AGESA.
rohowsky
Thanks man! It worked. :)
Now everything seems to be working. The only issue is an error that I get every time I run macOS . It's about mismatched RAM modules and maximum supported memory (see picture below). Should I change the ram modules' position on the motherboard?
Currently, I am using the slots suggested on the mainboard's manual for the first two modules.
From that I can say you are using MacPro7,1 SMBios. Change it to iMacPro1,1 and you'll fix that issue.
