(solved) RX580 not working after sierra install
TylerTT
Hello, when I install macOS Sierra everything goes fine and the GPU works but after the install my GPU isn't outputting anything to the monitors but the system is booted is there anyway to fix this?
Thanks
(Not High Sierra)
Did you try different display ports?
TylerTT
Do you have Whatevergreen.kext?
TylerTT
