Ryzen 3 3250U (Dali) laptop: Monterey boots, Ventura/Sonoma/Tahoe freeze at "kdp_core zlib memory 0x7000"
Zen
13
ryzen 3 3250U
Hardware: Dell Inspiron 15 3525, Ryzen 3 3250U (2C/4T, Dali), Vega 3 iGPU, 8 GB RAM, KIOXIA KBG50ZNS NVMe, BIOS 1.36.0 (InsydeH2O, no CSM, Above 4G already on, SATA = AHCI, Secure Boot off).
Working: Monterey 12.7.6 runs with OpenCore REL-109 and AMD_Vanilla patches (core count 02, Shaneee PAT patches, DummyPowerManagement, NootedRed, ForgedInvariant, RestrictEvents).
Problem: Ventura 13.7.x (Darwin 22.6.0), Sonoma 14.6 (23.6.0) and Tahoe all stop dead at kdp_core zlib memory 0x7000, with no panic and no further output.
Verified: OpenCore log shows MAT support is 1, all AMD kernel patches applied successfully, kexts injected.
Tried without change: every Booter quirk set, with and without custom ACPI/SSDTs and HPET patches, minimal kexts (Lilu, VirtualSMC, WhateverGreen only), algrey vs Shaneee PAT patches, cpus=1, npci=0x2000, the IOPCIIsHotplugPort patch enabled, SecureBootModel Default/Disabled, and an OpCore Simplify-generated EFI.
Has anyone gotten Ventura or newer to boot on a Dali/Picasso (Ryzen 3 3250U/3200U, Athlon) dual-core laptop? Any patch or quirk I'm missing?
No EFI folder attached to your last post.
Where?
Again nothing attached to the post above.
How are you trying to attach the EFI folder?​
You need to Zip/compress the folder and attach the zipped container for it to work.​
Questions:
1. How have you configured your AMD IGPU?
How much VRAM have you allocated to the IGPU, it needs to a minimum of 1G to work without any issues in macOS.​
2G would be better, and is the base limit I use on any of my Hacks. But as you only have 8G RAM you will probably need the 7G RAM to run macOS.​
2. Have you used Smokeless UMAF to edit the VRAM (UMA buffer size) allocation?
I have used it without issue on a couple of Lenovo AMD laptop and a couple of HP Mini Desktop hacks.​
Where?
Questions:
Hi Edhawk, thanks for the reply, and sorry about the attachments. They kept disappearing when I clicked Post, so I'm posting a link to the files instead: https://drive.google.com/file/d/1ouXM4gCPXMfDcPBWI_8uLYujzMZSItn8/view?usp=drive_link. It has my config.plist, the ACPI folder and a list of the kexts and versions. I removed the serial, MLB, UUID and ROM first.
To answer your questions:
1. I haven't changed the iGPU memory allocation. This is a Dell Inspiron 15 3525 with an InsydeH2O BIOS (version 1.36.0). The Advanced tab only shows things like Integrated NIC, USB Emulation, SATA Operation and battery options. There is no UMA Frame Buffer option, so I don't know what the iGPU is currently set to. Windows GPU-Z reports Above 4G Decode as enabled and CSM as disabled, and the BAR sizes are 256 MB and 2 MB.
2. I haven't used Smokeless UMAF yet. I'm a bit cautious about changing hidden BIOS settings on a laptop with only 8 GB of RAM. If you think it's worth trying, I'd set only iGPU Configuration to UMA_SPECIFIED and UMA Frame Buffer Size to 2G, and I'd photograph the original values first.
One thing I wanted to ask. The freeze happens very early, at kdp_core zlib memory 0x7000, before any graphics kext loads. I get the same freeze with NootedRed removed from the EFI (only Lilu, VirtualSMC and WhateverGreen loaded). Do you think the UMA size could really affect this stage?
For reference, Monterey 12.7.6 boots and runs fine with this EFI. Ventura 13.7.x (kernel 22.6.0), Sonoma 14.6 (23.6.0) and a Tahoe EFI from OpCore Simplify all stop at the same line. I've also tried npci=0x2000, the IOPCIIsHotplugPort patch enabled, Shaneee versus algrey PAT patches, and different Booter quirk sets. My OpenCore log shows MAT support is 1 and all kernel patches applying successfully.
Thanks again for your help.
Access denied on Google Drive. You need to provide a link that isn't access protected, i.e. one you share with others.
Better yet, zip the EFI folder and attach a copy here, like I requested.
Hi Edhawk,
Sorry about the access issue earlier. I have updated the Google Drive permissions, so the link is now public and available to download.
I tried to zip the EFI folder and attach it here like you asked, but the zip file is around 9MB. It seems that is too large for the forum's attachment limit, because the file keeps disappearing when I try to post it.
Here is the working Google Drive link instead:
Let me know if you can download it now.
I have downloaded the EFI folder and I am currently having a look through the folders contents.
The first thing I notice is that you have too many kexts in your setup for a Tahoe installation. It is normal to use a minimal set of kexts when installing Tahoe, as non-essential kexts can throw up issues during the installation that they don't during a normal boot, i.e. once the OS has been installed.
The essential kexts in your case would be these.
  1. Lilu.kext
  2. VirtualSMC.kext
  3. AppleMCEReporterDisabler.kext
  4. SMCBatteryManager.kext
  5. VoodooI2C.kext
  6. VoodooI2CHID.kext
  7. VoodooPS2Controller.kext
Plus your laptop's Ethernet kext, assuming your laptop contains an Ethernet port, some don't.
Your USBToolBox.kext and UTBMap.kext while fine in Sequoia and earlier versions of macOS, isn't compatible with Tahoe. Apple introduced a new USB port numbering and naming convention when Tahoe was released and UTBMap.kext hasn't been updated to take this into account.
You need to create a new kext, USBMap.kext with the latest version of Corpnewt's USBMap script or USBPorts.kext using Hackintool's USB tab version 4.14, 4.15 or newer. Both of these options will create a Tahoe compatible USB kext from your current UTBMap.kext configuration. This should be undertaken in an older version of macOS, such as Monterey, assuming you still have access to the OS.
You will notice that I didn't include NootedRed.kext in the list above. That is because it is sometimes necessary to disable or remove this kext when installing Sequoia &/or Tahoe. It can be enabled/added back to the OC setup once you have reached the Desktop. Having it enabled during the installation can cause unnecessary issues, which we want to minimise.
Same goes for a number of the other kexts I omitted from the list above, especially AMDRyzenCPUPowerManagement.kext and any Sensor kexts. These are really not needed during the OS installation and can be added back once the OS has been installed.
You have some work to do.
  1. Lilu.kext
  2. VirtualSMC.kext
  5. VoodooI2C.kext
Hi Edhawk, thanks for going through the EFI and for the kext advice. I followed it and rebuilt the Tahoe EFI with only: Lilu, VirtualSMC, AppleMCEReporterDisabler, SMCBatteryManager, VoodooI2C (with its plugins), VoodooI2CHID and VoodooPS2Controller (plus AMFIPass, which OpCore Simplify added for Tahoe). I turned off NootedRed, ForgedInvariant, RestrictEvents, AppleALC, NVMeFix, all the sensor kexts, rtw88, USBToolBox and UTBMap.
It still freezes at the same place. The photo is attached. The kernel is Darwin 25.6.0 (xnu-12377.161.14), and the last line is: kdp_core zlib memory 0x7000. There is no panic and nothing more is printed.
This is the same line where Ventura 13.7.x (22.6.0) and Sonoma 14.6 (23.6.0) stop. Monterey 12.7.6 (21.6.0) boots fine with the same hardware. The freeze comes before any kext loads, and I got the same freeze earlier with only Lilu, VirtualSMC and WhateverGreen enabled, so I don't think the kexts are causing it.
Things I have already tried without any change: npci=0x2000, the IOPCIIsHotplugPort patch enabled, Shaneee versus algrey PAT patches, different Booter quirk sets (including the old firmware combination), no custom SSDTs, and SecureBootModel Default and Disabled. The OpenCore log shows MAT support is 1 and that all the kernel patches applied successfully.
You mentioned the iGPU VRAM. My Dell BIOS has no UMA Frame Buffer option, so I haven't changed it yet. Do you think I should try Smokeless UMAF and set UMA to 2G, even though the freeze happens this early? Or is there anything else you would check first?
Thanks again for your time.
Post a copy of your current EFI folder. Zip and attach it to a post below.
Post a copy of your ACPI tables, see this guide for how to obtain the ACPI tables. Again, zip and attach a copy to b post below.
Hi Edhawk, I’ve attached both files: a zip of my current EFI (the Tahoe test setup with your minimal kexts, with the serial, MLB, UUID and ROM removed) and a zip of my ACPI tables (dumped with SSDTTime on Windows; I left out MSDM and SLIC because they contain license data). The system is a Dell Inspiron 15 3525 with a Ryzen 3 3250U. Let me know if you need anything else
Hi Edhawk, a quick update with everything I've tested since your last message, in case it helps.
1. I set the iGPU UMA frame buffer to 2 GB with Smokeless UMAF before running all the Tahoe, Ventura and Sonoma tests below. It still freezes at the same line.
2. I found a public EFI for the same CPU (Lenovo IdeaPad 3 15ADA6, Ryzen 3 3250U) that boots Ventura 13.7.8: github.com/andygeeked/Lenovo-IdeaPad-3-15ADA6-Hackintosh. I tried two things with it:
- Test A: my EFI with its Booter quirks (EnableWriteUnprotector, RebuildAppleMemoryMap, SyncRuntimePermissions, SetupVirtualMap and FixupAppleEfiImages all on). It froze at the same line.
- Test B: that whole EFI, unchanged apart from my own serial, MLB, UUID and ROM. It froze at the same line on Ventura.
3. I also tried: maxmem=4096, npci=0x2000, the IOPCIIsHotplugPort patch enabled, both PAT patch variants, cpus=1, a build with no custom ACPI, and the OpCore Simplify Tahoe EFI with your minimal kext list.
4. I waited 15 minutes after the freeze. The screen did not change and the fan stayed quiet, so it looks like a real hang and not only a dead display.
The freeze happens at "kdp_core zlib memory 0x7000" on Ventura 13.4 and 13.7.x (kernels 22.5.0 and 22.6.0), Sonoma 14.6 (23.6.0) and Tahoe (25.6.0). Monterey 12.7.6 (21.6.0) boots and runs with my EFI. The machine is a Dell Inspiron 15 3525 with BIOS 1.36.0, a Ryzen 3 3250U and 8 GB of RAM. The Lenovo has 20 GB of RAM and an older BIOS.
Do you have any idea what else could differ between these two machines? Thank you for your time and help.
The logical difference would be Bios settings, those that are visible and those that are hidden by the respective manufacturers. I would take note of the Bios setting available and changed to match the recommended settings on the Dell and then see how that compares to the Lenovo’s Bios settings.
What if anything is different?
Can the difference be patched with the use of a OpenCore Quirk or Boot Argument?
Hi Edhawk, an update after your BIOS suggestion. I tested the hidden AMD settings one at a time with Smokeless UMAF and none of them changed the freeze. I booted Ventura 13.4 (kernel 22.5.0) from the USB with the Lenovo 3250U EFI each time, and it always stopped at the same line: "kdp_core zlib memory 0x7000".
Settings I tried:
1. Global C-state Control: Auto changed to Disabled.
2. IOMMU: Auto changed to Disabled.
3. DF C-state control: Auto changed to Disabled together with Above 4GB MMIO Limit: 40bit (1TB) changed to 36bit (64GB).
I have also kept the UMA frame buffer at 2 GB since before the other tests. Everything else in AMD CBS and PBS is on Auto or the Dell default. There is no Local APIC Mode setting in this BIOS, and Core/Thread Enablement only shows a warning, so I left it alone.
Since the full EFI from a working Ryzen 3 3250U (Lenovo IdeaPad 3 15ADA6) freezes the same way on my Dell, I think the cause may be something about the Dell firmware itself. Is there anything else you would check, or a boot argument or quirk that could cover a firmware difference at this stage? Thank you.
Settings I tried:
The only entry you needed to change with Smokeless_UMAF was the UMA value, and then only if you couldn't do so in the Dell Bios.
All the rest should have been left as they were.
I would recommend using the Bios Defaults to reset any inappropriate changes you made to the Bios with Smokeless_UMAF.
Then make the recommended changes for your AMD Hack in the normal Dell bios, those that are available.
Only use Smokeless_UMAF to increase the UMA value to 2GB or more, depending on the amount of RAM available in your system, i.e. only increase the UMA to 4G if you have 20G+ in your system.
These are the standard AMD Bios changes.
AMD BIOS Settings
Disable
  • Fast Boot
  • Secure Boot
  • Serial/COM Port
  • Parallel Port
  • IOMMU
Enable
  • Above 4G Decoding (This must be on if present).
    • if you can't find the Above 4G Decoding option then add npci=0x3000 to boot-args.
    • Do not have both the Above 4G Decoding option and npci enabled at the same time.
  • EHCI/XHCI Hand-off (Set to Enabled not Auto)
  • SATA Mode: AHCI (Set to Enabled not Auto)
Changing unnecessary bios options is more likely to cause issues than it is to solve your current issue.
AMD BIOS Settings
Disable
  • Fast Boot
  • Secure Boot
  • Serial/COM Port
  • Parallel Port
  • IOMMU
Enable
Hi Edhawk, thank you for the clear summary of the standard AMD BIOS settings. Here is where my Dell stands against your list:
  • Secure Boot is disabled, SATA Operation is AHCI, and the BIOS is UEFI only with no CSM.
  • Above 4G Decoding is enabled by the firmware (GPU-Z shows Above 4G Decode enabled), but the Dell BIOS has no visible option for it.
  • There are no visible options for Fast Boot, the serial and parallel ports, or XHCI hand-off.
  • IOMMU: I tested it Disabled, and it did not change the freeze.
The only value I have left changed in the hidden menus is the UMA frame buffer (2 GB). I put the other settings I tested (Global C-state, IOMMU, DF C-state and the Above 4GB MMIO limit) back to their original values, so I did not reset the whole BIOS.
As you suggested for BIOSes without an Above 4G option, I also tested npci=0x3000 with the full Ryzen 3 3250U Lenovo EFI on Ventura 13.4 (kernel 22.5.0). It still stops at the same line: "kdp_core zlib memory 0x7000". I had already tried npci=0x2000 earlier with the same result.
So the freeze remains on Ventura, Sonoma, Sequoia and Tahoe with every EFI I have tried, while Monterey 12.7.6 works. Do you have any other idea, or do you think this Dell firmware simply cannot run these kernels? Thank you again for your time.
No, I think the question you should be asking is what changed between Monterey and Ventura to make the Dell system Freeze, but allowed Monterey to install OK.
Did you change the SMBIOS from iMacPro1,1 to MacPro7,1 for your Hack to run newer versions of macOS?
Did you add any more memory to the system?
Did you change the macOS drive you are using?
If it was a Bios issue then you would be prevented from booting all of the OS's including Monterey.
Just so you know 'Fast Boot' might have a different name in the Dell bios. I know my Lenovo laptops use 'Quick Boot' in place of 'Fast Boot'.
