Install goes back to macOS Utilities
Vivi1337
Hello!
I made my vanilla installer by the tutorial. I can boot the installer from the pendrive fine, make the partition then click on reinstall macos. After I select partition, and click install the installer close itself and go back to the macOS Utilities page. Internet connection is okay.
I tried an another pendrive maybe it's faulty but the same happens.
Any solution? :o
MOBO: ASus prime x370-pro
CPU: Ryzen 5 3600x
RAM: Corsair vengeance 3000mhz
GPU: Sapphire Nitro+ 5700XT
My build I am trying get booted is very close to yours, same mo, cpu, RAM, but I have a 5600x. I Get to the start Catalina and then nothing. How are you formatting the drive?
AFPS and GUID?
Hello!
Any solution? :eek:
CPU: Ryzen 5 3600x
Have you tried to make full installer usb drive?
Have you tried to use a different USB drive? Also to make the full installer skip the step in the guide in the gibMacOS part for typing -R for the recovery options. This will download all the files required.
I have the same issue have you got any solution for this?
Works!
I installed Mojave first then I upgraded it to Catalina. Mojave installer works as charm.
