Gigabyte X670e Aorus Master - Problems with Install Boot
Caldir
44
Germany
Ryzen 9 9950x
Hi i did ryzentosh 6 years ago...
which kext should i use for GPU Tahoe whatevergreen.kext or NootRX.kext?
Something wrong with my CPU Mapping ?
    config.plist
    EFI.zip
Use SMBIOs for MacPro7,1, the iMacPro1,1 isn't supported in Tahoe.
You don't need most of those boot arguments. Remove these.
keepsyms=1 debug=0x100 igfxonln=1 alcdelay=1000 log_buf_len=8388608
Unless there is something really relevant updated for your system, which you can't do without, I would recommend sticking with your current Bios. It works, so leave it be until you actually need what the new Bios is offering.
Reactions: Caldir
Thanks tomorrow i will Map again ;)
Maybe Perplexity can help me i will send them everything i know about my mappings let us see ;)
EDIT: Ya, Sir.
don't need this Boot Args i will try Tahoe MacOS Installer with -v
I almost can install fresh with Boot Stick from Tahoe it :D, the Update was an Issue dont know why ...
Small Update New Error from Tahoe Install, it is kind of weird.
Because under sequoia the EFI runs almost flawless unless the USB Mapping.
Here is a screenshot from the Problem
The most common issue when looking to install Tahoe is an over populated /EFI/OC/Kexts folder. The trick is to disable or delete any kexts that are not essential to getting Tahoe installed. A Kexts folder contain just these Kexts might be what you need to use.
  • Lilu.kext
  • VirtualSMC.kext
  • AppleMCEReporterDisabler.kext
  • USBPorts.kext or USBMap.kext that has been updated to work with Tahoe.
    • USBToolBox.kext & UTBMap.kext won’t work in Tahoe, as the UTBMap configuration lacks the new port name and number requirement for Tahoe.
    • The methods for generating either of other two USB kexts have been updated in their respective Application/Script so they will work with Tahoe.
    • You just need to make sure if you are using Sequoia that you use one of the two methods to generate a new kext based on your current configuration.
  • Ethernet kext (whichever one you need for your motherboard)
  • WhateverGreen.kext version 1.7.1d7, see link below.
I would also recommend using this Kernel patch when running a fresh/clean installation of Tahoe. As it prevents the installer from implementing FileVault encryption on your macOS drive. As this would result in you not being able to sign in to your account on the macOS login screen.
Hope this helps.
Reactions: Caldir
it works for now some tests then I know about benchmark scores.
Sometimes i got a Black screen, but next time it boots wellt O.o
now it boots after 1 boot loop, kind of weird
-v -amfipassbeta agdpmod=pikera alcid=1
EDIT New Boot Arg Seems to work flawless:
-v agdpmod=pikera alcid=1
By the way... how is this mapping ?
Now get some Boot issues on Tahoe, sometimes in works / Black Screen or reboot :(
Nothing change use old EFI and New one's doenst matter
EDIT2: Maybe cuz i wanna update the system ? Something broken inside the macOS ?
Should i Reinstall ?
It's inexplicable to me why these various errors are occurring.
I boot with an EFI that worked perfectly before, but now it doesn't.
Sometimes, after selecting the USB drive in the boot menu, nothing happens, and the system jumps straight back to the boot menu.
Another phenomenon is a black screen after almost everything has finished running. I started with -v boot arg, so I couldn't identify any errors.
Another issue occurs after almost everything has finished running: a restart.
And finally, sometimes the system gets stuck on AHCI.
I still absolutely don't understand why everything worked before.
It's driving me crazy. Even Sequoia doesn't work anymore.
The EFIs were newly created, and some were old. I'm starting to think the motherboard might actually be faulty. An alternative would be to buy a used Asus board and try it out on a test bench. Otherwise, switch completely to macOS, as updates for Tahoe will also cease.
EDIT: TRY different Bios now is F38 dec. , also try now 41 - NVME Reset. Sometimes i tink the EFI change be it self or Memory is not clean somehting like that.
Changing the Bios, without checking to see if the system DSDT.aml needs new or different patches isn’t a good thing to do.
Using the verbose boot argument (-v) can on some systems lead to a kernel panic, depends on what else has been enabled, I.e. Realtek Ethernet port/kext rings a bell.
Have you looked into copying the EFI folder from your USB Installer to the EFI Partition on the macOS drive? As that is how I and most Hackintosh users setup their Hacks, once they have macOS installed. See this Dortania page for details.
The more you change things from their original working version the more likely you are to introduce new problems.
Update:
I’m dealing with a very sporadic kernel panic / boot instability issue on my AM5 Hackintosh, and I’m trying to narrow down the cause.
My system:
  • AM5 Hackintosh
  • macOS booting via OpenCore
  • NVMe SSDs:
    • Samsung 9100 2TB
    • Samsung 970 EVO 1TB
  • SATA SSD:
    • SanDisk 500GB SATA SSD
  • I also use NVMeFix.kext
The problem does not happen all the time. It appears randomly, and I first suspected an AHCI / SATA issue.
What I found so far:
  • CrystalDiskInfo shows the SanDisk SSD as healthy:
    • 97% health
    • 37°C
    • no reallocated blocks
    • no CRC errors
  • CHKDSK in Windows also reports no file system problems and no bad sectors.
  • However, my boot logs show repeated AHCI messages like:
    • COMRESET did not proceed
    • WaitForLinkPresent
    • EnablePortOperation returned: 0xE00002D6
  • These messages seem to point to a SATA link / port / controller issue rather than a bad file system.
My main question:
Could an unstable SATA/AHCI device or port also cause kernel panics or boot problems in macOS, even if the SSD itself looks fine in SMART and CHKDSK?
At this point I’m wondering whether:
  • the SATA cable is bad,
  • the SATA port on the board is unstable,
  • the SanDisk SSD is causing the issue only under certain conditions,
  • or this is something else related to the Hackintosh setup.
Any ideas or suggestions would be appreciated.
Thanks!
These are all valid points.
  • the SATA cable is bad, yes this is a possible cause,
    • I would replace the cable but also check its replacement is firmly seated in the motherboard SATA port and connected to the SSD
    • The only way to know if the SATA port is to blame is to try all the other ports with the new SATA cable, to see if the issue is removed by using an alternative SATA port.
    • This is the least likely but still possible. not sure how you would test this theory.
  • or this is something else related to the Hackintosh setup,
    • Could be an issue with the AMD SATA Controller. I know of a couple of users who had issues with the AMD SATA controller on their Gigabyte motherboards, with no resolution to the issue. I was using a similar board (Asus not Gigabyte) with the same SATA controller but had no AHCI or SATA issues.
If you are using the SanDisk SSD for macOS, I would remove the two Samsung NVME drives and see if the issue occurs when they are not connected to the system.
Personally I would remove the two Samsung drives whatever, as neither are 100% compatible with macOS and these are more likely to cause issues, even if not used as the macOS drive.
Western Digital or SanDisk NVMe drives are the most compatible with macOS, as they use a compatible NVME controller to that used by Apple in their Intel Macs. I use WD SN570, SN580, SN770, SN850X drives in my hacks with no issues. The SanDisk 5100 and 7100 drives use similar NVME controllers and are known to work well with macOS. Do not look at the WD/SanDisk 8100 PCIe 5.0 x 4 drive as it uses an incompatible controller.
Do not use a PCIe 5.0 x 4 NVME drive, as none of them have a macOS compatible NVME controller (Phison, Silicon Motion & Phoenix controllers) as far as I can tell from my research.
Reactions: Caldir
I'm trying to turn off the SATA controller.
And let's see what happens. Since macOS is on the NVME, it's getting tiring... :ROFLMAO:
MacOS on your Samsung drive, may be adding to your problems. So don’t be surprised if your system continues to suffer, after deactivating the SATA controller in the Bios.
If the presence of the SATA SSD is important to your workflow, then I would look at installing a compatible PCIe SATA card, assuming you have a spare x4 or x1 PCIe slot. Something like this card,would work in macOS.
I have no idea how I managed to successfully complete the other installations before.
Maybe I should swap my motherboard for an
Asus Prime X670E-Pro WiFi; will it be better accepted by OSX?
The NVMe drives don't seem to be compatible either.
It's a lot of hassle. Rebuilding and replacing everything :-/
Or maybe I should just switch to a macOS device altogether.
Because updates will only be available for Apple devices from now on.
If you go back to your original posts in this thread, see which EFI works and which doesn't. Test them from a spare USB pen drive.
You wouldn't need to replace everything, just the motherboard to keep an AMD Hack running. It is a pity you bought the Samsung drives, as they have been persona non grata with macOS for some time.
If I am honest, I have been struggling with my Asus Prime X670E-Pro WiFi board, as the Bios isn't as friendly as some others. So would I recommend it to you, No.
In comparison my Asus STRIX B650E-F Gaming system works like a dream in Sequoia. It can be problematic in Tahoe, especially when using OCLP-PLUS or OCLP-MOD to get the Broadcom WiFi working, but other than that it runs Tahoe really well.
An Apple Device is always an option and going forward it is likely to be the only path for using macOS 27 or newer. However, the cost of purchasing an Apple system has recently increased dramatically, with the lower end models no longer available, as RAM and Storage costs skyrocket due to AI growth.
A little off topic but I am seeing the same result with my MSI X670E Tomahawk board. Perfect in Sequoia but failure to launch in Tahoe trying to implement OCLP-MOD/ Broadcom. Any insight as to why, bit of a head scratcher.
Reactions: Caldir
No idea, tried everything I could think of to get Tahoe working like Sequoia on my B650E-F Gaming system, but not had any joy. So reverted the system to just dual boot Windows and Sequoia. I'll probably go back to this but I am no in a rush, it's not as if a new OS is going to be released that we can use on our Hacks ever again!
I tried using OCLP-Plus v3.1.19 (now v3.1.21) on my system, as it seems to be more inline with the original OCLP process.
Reactions: Caldir
so with ASUS ROG x670E Hero maybe its better ?
X870 boards not good ?
X870 boards are definitely not a great option. Some users have been able to get them working such as this Success Story.
Selecting a AMD 600 Series is to my mind your best option. Not used the X670E Hero, so can’t say much about it. I doubt it is going to be any more difficult than other X670 boards.
See which boards are listed in CaseySJ’s guide, other than the Gene in the title.
