Where did you get the macOS ISO from? Did you use one of the download links in the first post?
hi so i was away and my brother got in my account and he loves to annoy people so the last few posts wasnt me
How can I find the reason the update fails on reboot to install:
After a restart, it goes back to 26.0.1
After a few minutes, it restarts, and the next screen is:
And it's back to 26.0.1 again
The Over The Air (OTA) Apple software update 5Gb download usually doesn’t work. A full 17Gb+ download is usually required for Tahoe on a Hack.
can i use my vm on another display like windows on one and mac vm on another through hdmi
You can have multiple VM’s running if your system is powerful enough to do so. However, a laptop might not be the best choice for such a setup.
If you have an 8-core CPU, then setting 4-cores to each VM may not be wise. You may need to manually edit the OC vmdk to only use 2 or 3-cores per VM, so you leave sufficient processing power for the Host OS. Plus you need to have sufficient memory available for the VM’s and host OS.
I would say that is an under powered 15W CPU, that has 4-cores and 8-threads.
Splitting it to support 3 x OS’s isn’t going to be a good idea. Running the Host and 1 x VM will probably be its limit. But I wouldn’t expect to be able to work in both at the same time, not without some extensive spinning beach ball stalls as processes are underway.
have you heard of ryzen controller its for overclocking amd laptops without flashing i usually use it to make ps2 emulation better i think it will work on vm and i meant multiple mac os installs inside one vm
No. I have not heard of the AMD Ryzen Controller software, but that is probably because it isn’t something I need.
No, you won’t be able to run multiple macOS instances within a single VM. The usual trick is to install multiple VM’s on the Host system each running a single guest OS. So sufficient capacity to handle the load is required on the host machine.
No, as I’ve not worked out what you have done for the installation to stall at that point.
Assuming you followed the guide and left the 4-core vmdk as it was when you downloaded it, then macOS Tahoe should install.
My Device Information:
AMD Ryzen 7 6800HS, RAM: SSD5 16GB, CPU: 8 Cores
I downloaded Tahoe.iso from the mentioned links (9 file combination), also vmdk 4 cores.
I followed the guide correctly, but I am getting issue like this.
What's my mistake?
Please help me.
Does sound work on Tahoe 26.4, and which kext to use?
Built in audio even on a bare metal installation requires a post installation fix (adding AppleHDA.kext to Tahoe) before sound will work. The same fix may (MAY) work in a VM, but it is not something I have tried.
You might have more luck using a USB Audio dongle/device in your VM, as the kexts/dexts are already installed in Tahoe.
Just make sure you select the correct sound device in System Information > Sound preferences pane, as macOS doesn't automatically change to the correct sound device.
Reactions: darkony
@SwiftDev care to explain how you solved the issue, so others in the same predicament can learn from your success?
Reactions: tangcla
What's my mistake?
Please help me.
i have the same issue, stuck at this screen after clicking "install macos tahoe"
@dmzuck don't expect too much help with your problem.
You have simply overloaded everyone with information, so much so that they won't know where to start!
Reactions: tangcla
