Intermittent freezes
Guantanamera
43
ryzen7 5800H
hello everyone !!
I managed to install Tahoe 26.2 with built-in Wi-Fi. I think everything works, but the problem is that it freezes intermittently. Any suggestions on how to fix this?
Thanks
Same for me, after fresh install, non predictable freeze/stuck with CPU fan sound.
I attach the error (probably CPU peak of charge or GPU fail) Vision D /Bios 18/ 6900XT/ NVME / 128RAM/
Have you checked the CPU & GPU temperatures when the freeze/crash occurred? CPU fan noise would indicate a cooling/thermal problem.
Reactions: Loukoum_31
In my case that happens, there is no fan acceleration
Do the following:
1. Check the CPU fan connection is fully seated in the motherboard plug/fan header.
2. Check the fan cable is not damaged or being pinched by any other components when the base is attached.
3. Check the thermal paste hasn’t dried out and is no longer functioning. I replace the thermal paste on my Desktop systems every 3 years (did this today for an AMD Hack), on a laptop I try to do this every 2 years.
4. Check the heatsink is in full contact with the CPU.
5. Check the CPU fan works as the system boots, i.e. have the case open while booting the system. Obviously this will be easier for a desktop system.
6. Check the Troubleshooting LED’s on the motherboard are not showing an issue when the system boots, might cause an extended delay to the boot time, or for the system to reset and boot again before getting past the error. Again easier with a Desktop system.
Do the following:
Thanks for your feedback, I'll check what you said. The thing is, when I have Sonoma installed, it runs smoothly.
It was the same for me, the freeze is only appear with Tahoe. I have a triple boot, and the other system are working well. I have tried to monitor the temperatures of CPU Fan with AMD Power Gadget, nothing special. Maybe a NVME management trouble in my case with Sabrent.
Same problem on SSD. I will clean the hardware as mentioned Edhawk. I attach my EFI, if you can check. Thanks
I have the same problem: the fan is going crazy. I have the impression that Tahoe has damaged the graphics card.
If I start the computer and stay in the BIOS, it freezes.
Now it's impossible to install any system.
With the Radeon 5500 XT, it restarts at the first step of the installation. All this because of this Tahoe system, which is awful and offers no improvements whatsoever. I miss the Sierra system, which was much better. It's true that releasing new systems every year... how can you expect to make something decent?
Just to confirm that in my case it is the freeze trouble is only with Tahoe, I have both OS Sequoia and Tahoe installed on my computer.
With a very new clean OpenCore and after a very useful cleaning hardware ;) Sequoia works very well (only Thunderbolt patch need to be update, maybe a new hackindrom mapping du to ACPI changes ?).I have tested lot of changes for Tahoe, but without success, maybe update kext (Lila) could help to CPU panic.
The freezing issue unlikely to be related to the kexts. It is more likely to be caused by hardware incompatibility where the new OS requires something more than is currently available.
Tahoe definitely needs a new USB map, as Apple changed how the USB ports are identified. A UTBMap.kext created in Windows won’t work in Tahoe, as it lacks the new naming convention. You would need to be using a USBMap.kext created using the latest version of Corpnewt’s USBMap script for the USB ports to work in Tahoe.
You should have updated the essential kexts in your /EFI/OC/Kexts folder when you installed Tahoe.
Thanks Edhawk,
I have generated my own USBMap.kext created with Corpnewt’s USBMap script, unfortunately the Tahoe freeze is still a active.
But my Sequoia OS works, very, very well with this kext.
For Tahoe, I can't identify the kext that is causing the problem....
Reactions: Edhawk
Ok after many and many researching test and comparaison between my Sequoia (woking) and Tahoe (freezing), the guilty kext is AppleIGB....
The last existing version I have 5.11.4 is creating the non predictive freeze under Tahoe. This bug is similar under Sequoia without the AppleIGB.kext.
Maybe an update of the Noyau max is needed ?
Maybe what you need to do is add a PCIe Ethernet card to your Hack, one that uses a compatible driver that works in Tahoe. That way you will completely remove the freezing issue.
I first used Realtek RTL8125B Ethernet cards in place of the Intel Ethernet devices built in to a number of my motherboards, but not in Tahoe. The 2.5G switches I used were problematic and unreliable so I had to think again.
I then switched to Aquantia/Marvell AQC107 & AQC113 PCIe cards, as I upgraded the Switch serving my home network to a business/enterprise class 10G switch. Using the patches provided by CaseySJ on his GitHub repository has meant I haven’t had any Ethernet issues dual booting macOS & Windows.
But in my case, I don't use the kext. AppleIGB?. Edhawk, You can take a look at my OC please?
Sure on Friday, when I am next at my desk.
I'm not sure if this is relevant to your hardware, but I had freezing on Tahoe due to random kernel panics caused by my BT/Wifi hardware (Intel), @Shaneee informed me that it's a known issue on Tahoe - doesn't occur on Sequioa, so I reverted back.
I confirm that the intel ethernet onboard controller is the issue on Tahoe under Vision D B550.
I disabled it in the bios, and the the Tahoe is working well with only wifi heliport.
Maybe a an update of the AppleIGB could help ?
I would like to add a PCIe Ethernet card as Aquantia/Marvell AQC107 & AQC113 but in my case all the PCI lines are full (two graphique cards, Dual boot NVME...)
Reactions: alliance
Nice!
It sounds like you were getting the same kernel panics from Intel ethernet, as I did when I used Intel BT/Wifi.
Glad it helped!
The Ethernet port not working correctly and causing issues is probably because our AMD hacks lack AppleVTD, which is required for a lot of the newer Dexts Apple have added to macOS in place of the older Kexts.
Some components such as the Intel Ethernet controller are more reliant on these Dexts and AppleVTD. If we could find a way to add AppleVTD to our AMD systems it would make life a lot easier.
