[Sequoia | Ryzen 9 9950X + RX 6600 + X870-F] Boot stuck
rrysio6
10
x9950
Hi everyone,
I’ve been trying to get macOS Sequoia running on my system for the past two weeks, but unfortunately, I’ve hit a wall.
My setup:
  • CPU: AMD Ryzen 9 9950X
  • Motherboard: ASUS ROG STRIX X870-F GAMING WIFI
  • GPU: AMD Radeon RX 6600
I’ve been working with both OpenCore-Simplify and various prebuilt EFI configurations I found on the forum. The furthest I got was using this configuration shared by master fabiosun : 🔗 Link to the post
Without any modifications, this EFI allowed me to get the furthest in the boot process — but now I’m stuck at a point I just can’t get past. I’ve tried multiple tweaks and approaches, but the issue persists.
I usually prefer solving things on my own and rarely ask for help, but this time I’m out of ideas and energy. I’d greatly appreciate any tips, advice, or insights.
Thanks in advance! 🙏
I did something terrible… 😞 I updated the BIOS to the latest version https://rog.asus.com/motherboards/rog-strix/rog-strix-x870-f-gaming-wifi/helpdesk_bios/
1.AGESA updated to ComboAM5 PI 1.2.7.0.
2.Improves compatibility with various CPUs and devices.
Note: This BIOS version cannot be rolled back to previous versions.
Now any changes in the configuration stop me on the same log screen.
That’s how it was, but now I can’t confirm it.
Make sure your bios settings are correct after the update, if they are fine and it still hangs on boot you may need new ACPI patching.
Reactions: rrysio6
i did the same your error to updqte my hero and OSX does not boot anymore
i recovered my working OSX via flashback button and old previuos bios
That's right, I asked CorpGhost for an ACPI fix, and that resolved the BIOS update issue for me.
I still have two issues that need to be resolved:
  1. Non-deterministic installer boot
    With identical BIOS settings and the same config.plist, the system often freezes on a black screen just before reaching the macOS installer GUI. This happens randomly — roughly in a 6:1 ratio (i.e., only about every sixth boot successfully reaches the installer). I’ve tried various configurations, but currently I’m using the one that gives me the highest success rate when loading the installer.
  2. Installer freezes 12 minutes before completion
    The installation process freezes approximately 12 minutes before finishing. After rebooting, it cannot resume — the system does not continue the installation.
    For context, I’m using a Samsung 970 EVO Plus SSD with the latest firmware, so in theory, that shouldn't be the cause.
Reactions: leesurone
Actually this drive is not recommend for long term use but is probably not causing the boot issues. My thoughts are the lack of proper USB Port mapping could be the problem. UTBDefault.kext is just a work around.
