Battery Not Detected During Dual-Boot
anjayghale
Ryzen 5 3500U
Hello,
I have an issue when dual boot with OpenCore (Win10/Hackintosh)
When i enter Win10, it always not detecting the battery but it's normal when i checked it at MyASUS app
My laptop is ASUS Vivobook X421DA_M413DA
Maybe there is better solution, because i'm new and not setting more on the OS X after installation
Does the' no battery' issue occur when you restart the system after first using macOS and then booting in to Windows 10? Or does it happen even if you boot in to Windows 10 first?
Do you have the battery showing and working in macOS?
Which kext(s) are you using to fix the battery issue in macOS?
I get it even i boot fir the first time. And now i cannot boot to Windows with OpenCore boot (back to OpenCore and for third time will got bluescreen "the device not properly blablabla and option to UEFI or set the mode of booting". I always change it via BIOS mode to native windows boot. My battery in masOS are detected normally. I attach my EFI (actually i just got it on the internet, it's not the exact same type vivobook but it works because have same CPU). Also my AIDA64 report if there is some advice for that. (I try to update the kext and just always got kernel panic)
I also try to fix my backlight issue (key and not turn on), touchpad (not active), audio (try to find right number arcg(?)) and brightness key issue.
LOL! you are using an EFI for a different laptop and wonder why you have issues.
If you can't be bothered to create your own EFI, why would anyone want to help you with an EFI not designed for your system?
I already created myself, it always got kernel panic. So i try with other EFI that have most similar hardware and try to modify it.
I not giving the fully context, so just ask it first anyway.
