macOS Tahoe on Asus rog strix g15 g153ih-hn026t
bblnae
AMD Ryzen 7 4800H
I’m trying to install macOS Tahoe on my Asus rog strix g15 with an Ryzen 7 4800h with gtx 1650 dissabled. I get a support error screen when trying to boot. I’ve been stuck here for the past two months, I have tried making new efi’s from scratch etc noting worked.
Here’s my efi: https://drive.google.com/drive/folders/11WSfmVaMccoSbddnkEP66ZmZ2Lk-Pf6t
If you have a USB kext in your current OC EFI disable it and try booting into macOS Tahoe again.
I am assuming you haven't used Corpnewt's latest USBMap script (Tahoe Beta) release to configure your USB ports.
Out of curiosity have you previously run Sequoia or an earlier version of macOS on your laptop?
Out of curiosity have you previously run Sequoia or an earlier version of macOS on your laptop thanks
Thanks! I will try that. No I’ve never booted another macOS version in this.
Have you ever built or successfully run macOS on another Hack (intel or AMD)?
If you haven't booted another version of macOS on this ASUS system, you are really setting yourself up for a whole host of issues. As the Beta OS is likely to throw more issues at you than a version that has been thoroughly tested and used by other AMD users.
You should try installing macOS Ventura first, as it has less issues to deal with than the more recent versions.
Are you using another hack or real Mac to create your installer and EFI?
Or are you using Windows/Linux?
