Problems with upgrading to Big Sur
POCTEXHAD3OP
35
Hello. I have installed macOS big sur update. After restarting the computer, it starts up on the "MacOS Installer" and hangs on this line.
I have MacOS Cataliina 10.15.6 and OpenCore Bootloader 0.6.0.
CPU: Amd Ryzen 5 1400
This is my EFI
    EFI.zip
This is my EFI
I looked at your config.plist but it does not look like it has the Big Sur patches. Available here.
If I can answer it, I will try. If not, the community may be able to help.
1) I installed patches for Big Sur. I selected 'MacOS installer' in the menu and the installation started. There was a bar under the Apple icon that said 'less than a minute left', and it hovered. How can I fix this?
2) Can you explain how to change the default device in OpenCore so that after downloading Opencore, windows loads after a while instead of MacOS?
Hold ctrl and press enter/return on the entry you would like as “default”
Reactions: AppleManDos
1) I cannot help with this. For me, it will reboot on its own after it reaches less than a minute left. After rebooting, does OpenCore see a new bootable partition such as preboot? If so, have you attempted to boot from it? My uneducated and unresearched guess is that the installer cannot communicate with your hardware correctly to initiate a shutdown or reboot.
2) savage001 answered your question. Please note that if you reset your NVRAM, you will need to Ctrl-Enter your default selection again.
