Install error Tahoe Beta 4
Gaodek
13
Ryzen 7700x
1000584250.jpgHey everyone. Anyone know what this error could be? I'm trying to install Tahoe beta 4. This EFI usually works fine with Sequoia.
Usb Map patched for Tahoe
Rog B650E-E gaming wi-fi
6900XT Asus LC
32gb xpg Blade
1tb crucial
Couple of preliminary questions:
  • Are you using the latest AMD-OSX kernel patches from here?
  • Are you using OpenCore 1.0.5 and the latest kexts?
Reactions: Gaodek
Hi @CaseySJ .
Yeah, I'm using the beta patches for Tahoe, and I'm on OpenCore 1.0.5 with all kexts updated, but nothing's working. Sequoia runs perfectly, though.
Later, I'll share my EFI, Casey.
Thanks so much for replying. Thanks to your threads, I learned how to install a Hackintosh.
Reactions: CaseySJ
If Sequoia runs perfectly, that is a good sign. It means we don’t have to worry about DSDT patches and MMIO whitelist. Incidentally, does Sequoia boot using the same EFI folder that you’re using to install Tahoe?
Which System Product Name are you using? iMacPro1,1 or MacPro7,1?
I’ll audit your EFI once it’s posted.
Reactions: Gaodek
Yeah.. Same EFI and Runs great in Sequoia.
MacPro7,1
Please try using the attached config.plist
Reactions: Gaodek
@CaseySJ .
Thanks for your help. I tried the config.plist you sent, but still no luck with Tahoe.
Sequoia keeps running perfectly.
I took a pic of the verbose output.
It looks like the verbose output changed...
I noticed that your USB is using USBToolBox instead of USBMap by CorpNewt. It would be advisable to rebuild the USB map. Tahoe is very particular about USB mapping.
Reactions: Gaodek
I’ve already tried with CorpNewt’s USBMap (the latest script for Tahoe) — I even still have the usbmap.kext saved.
I’m pretty much about to give up.
I’ve been trying to install Tahoe since the release of beta 1.
In the EFI folder you posted above, I did not see CorpNewt’s USB Map. I did see two USB kexts, both from USBToolBox.
Reactions: Gaodek
@CaseySJ Maybe I messed something up in the mapping (though I don't think I did). Either way, Casey, thanks a lot for your help. Maybe once the Tahoe is officially released, the kexts will get updated and my issue will be resolved.
Sorry, here's the EFI mapped by CorpNewt's latest script(and patched) for the Tahoe:
Some quick questions:
  • Did you create a USB install disk or did you download the Tahoe installer from Sequoia -> System Settings -> General -> Software Update?
    • Either option is fine, but I’d like to know which one we’re dealing with
  • Did you download the official release of OpenCore 1.0.5 from GitHub (not from Dortania)?
Reactions: Gaodek
1 - I'm trying to install using a USB drive that contains the "com.apple.recovery.boot" folder with the BaseSystem.dmg and BaseSystem.chunklist files. But I've also tried downloading the Tahoe installer through Sequoia -> System Settings -> General -> Software Update.
2 - It's the official release of OpenCore 1.0.5 from GitHub.
Reactions: CaseySJ
Please try booting both (a) Sequoia and (b) Tahoe Installer using the attached EFI folder without any modifications.
Reactions: Gaodek
I tried the EFI you sent:
Tahoe:
Same as always — no success.
Sequoia: It booted, but there was no internet connection
Hmm, Asus website says this board has an Intel 2.5Gb Ethernet port so AppleIGC should have worked in Sequoia. I disabled both the RealtekRtL8125 driver and AppleIntelEthenet. I also commented out the various device properties.
Running out of ideas now…
Reactions: Gaodek
AppleIGC sometimes works and then stops, and sometimes it doesn’t work at all. It’s been pretty problematic for me. I decided to buy an RTL8125, and that 'fixed' it.
Casey, honestly, thank you so much for your help. Sorry for the time you spent trying to help me. Maybe in future updates of Tahoe, the kexts, or OpenCore, my issue will be resolved.
I have installed Tahoe on 6 different Hackintoshes, 2 AMD and 4 Intel, without much difficulty.
So I’m scratching my head over this one! :)
If anyone else has any suggestions for @Gaodek, please chime in.
Reactions: Gaodek
