USB Map on Tahoe Beta 2 freezing keyboard and mouse
tatbt2010
31
5
ryzen 5 5600g
I use https://github.com/USBToolBox/tool for maping usb port for Tahoe beta 2, but after using the new USBMap.kext, I meeting freezing keyboard and mouse, I guess no usb port works,
Could anyone help me about this issue. thank you
My system is AMD spec in my signature.
Reactions: ccphuc
Yes, but I want to map usb for bluetooth
@Shaneee
I have a question about this mapping bluetooth. I dont know where to get Location ID, is it on Windows or Mac. Could you please help explain, thank you so much. This following guide I can see from your link, but I dont understand much
  • Intel Bluetooth Doesn't Show In Discovery
    • Due to the way Intel Bluetooth populates, it does not show in ioreg the same way other USB devices do. You can still find its address in System Information -> USB, then clicking on the bt device and taking note of its Location ID
    • This should be worked around as of this commit which merges info from system_profiler with ioreg to more completely map.
You can use USBMap by CorpNewt to map all USB ports, including the USB port used by Bluetooth. Here's what it looks like on my Asus X670E Gene. Be sure to change the USB port's "Type" to 255 as shown:
Reactions: ccphuc
what type TPLink USB Wifi W823N, 725N ?
@ccphuc
TP-Link AC600 is a WiFi module, not Bluetooth. If your question is whether Tahoe supports this USB WiFi module, I'm not sure. But it's very cheap so you can buy one and try it, although I don't think it will work...
