AMD FX-6300 (no integrated graphics core) & ASRock 970 Pro3 & GTX 960 HELP PLS #[EB.H.IS|!] Err(0xE) <- RT.GV boot-signature 7C436110-AB2A-4BBB-A880-F
08alks80
AMD FX-6300
Hi, my system:
CPU: AMD FX-6300 (no integrated graphics core)
Motherboard: ASRock 970 Pro3
GPU: Geforce GTX 960 4gb
I'm trying to install mac os sequoia but I get errors and hang on AAPL: #[EB|LOG:EXITBS:START].
Please help me solve these errors.
Here I see errors that need to be resolved:
AAPL: #[EB.H.IS|!] Err(0xE) <- RT.GV boot-signature 7C436110-AB2A-4BBB-A880-FE41995C9F82
AAPL: #[EB.H.IS|!] Err(0xE) <- RT.GV boot-image-key 7C436110-AB2A-4BBB-A880-FE41995C9F82
AAPL: #[EB.CFG.DEV|!] Err(0xE) <- RT.GV booter-strict-xmlparser 7C436110-AB2A-4BBB-A880-FE41995C9F82
AAPL: #[EB.H.LV|!] Err(0xE) <- RT.GV boot-signature 7C436110-AB2A-4BBB-A880-FE41995C9F82
AAPL: #[EB.H.LV|!] Err(0xE) <- RT.GV boot-image-key 7C436110-AB2A-4BBB-A880-FE41995C9F82
AAPL: #[EB.H.LV|!] Err(0xE) <- RT.GV boot-image 7C436110-AB2A-4BBB-A880-FE41995C9F82
AAPL: #[EB.H.LV|!] Err(0xE) <- RT.SV- boot-signature 7C436110-AB2A-4BBB-A880-FE41995C9F82
AAPL: #[EB.H.LV|!] Err(0xE) <- RT.SV- boot-image-key 7C436110-AB2A-4BBB-A880-FE41995C9F82
AAPL: #[EB.H.LV|!] Err(0xE) <- RT.SV- boot-image 7C436110-AB2A-4BBB-A880-FE41995C9F82
AAPL: #[EB.LD.OFS|OPEN!] Err(0xE) <"\\System\\Library\\CoreServices\\com.apple.Boot.plist">
AAPL: #[EB.OPT.LXF|LF!] Err(0xE)
AAPL: #[EB.OPT.RKS|!] Err(0xE) <- BS.LocP EDB4A040-6D8A-11EC-8FAD-3E22FB93ADCF
AAPL: #[EB.WL.PWLFNV|!] Err(0xE) <- RT.GV wake-failure 7C436110-AB2A-4BBB-A880-FE41995C9F82
AAPL: #[EB.WL.DT|!] Err(0xE) <- EB.WL.PWLFNV
AAPL: #[EB.LD.OFS|OPEN!] Err(0xE) <"usr\\standalone\\OS.dmg.root_hash">
AAPL: #[EB.RH.LRH|P!] Err(0xE) <- EB.LD.LF
AAPL: #[EB.BST.FBS|!] Err(0xE) <- EB.RH.LRH
Attached my last log and EFI
P.S DSTD.aml received from my OS Ubuntu
Hi, my system:
Your GPU limits the version of macOS you can install, read the comments in these posts here and ask yourself if it is worth the effort.
Ваш графический процессор ограничивает версию macOS, которую вы можете установить. Прочитайте комментарии в этих постах и спросите себя, стоит ли это того.
And if i install Radeon on my PC, then my system will be ready for installation Mac OS Sequoia?
Solution
It won’t run Sequoia, if it does it will be painfully slow and have some issues with common applications. These old FX CPU’s lack too many newer instruction sets to run anything newer than Monterey.
Reactions: leesurone
