help a newbie with the configuration for installing mac os ventura on a desktop pc!
SpringCat
16
AMD Ryzen 5 5600X
my configuration!
1. AMD RYZEN 5 5600X
2.ASROCK B450 STEEL LEGEND
3.NVIDIA GTX 1080 8GB
4.16GB DDR4
5.SSD/NVMe XPG GAMMIX D10 512GB DDR4
6.REALTEK RTL8111H
7.REALTEK ALC892
throws an error, I don't know what to do, please help
    EFI.zip
my configuration!
4.16GB DDR4
6.REALTEK RTL8111H
7.REALTEK ALC892
Are you aware your GPU is mostly unsupported and your CPU has no integrated graphics, the latest version you can install is High Sierra. Beyond that I didn't spend a lot of time examining you EFI although I did see somethings to edit (for example you do not need CPUR-SSDT.aml).
Yes, I know that my video card is supported by Mac OS 10.13, but I have seen many times that people with my video card or from the GTX generation launched graphics and the hackintosh worked fine. As for the processor, I also know that there is no graphics core! But is it possible to somehow log into the system without errors and start graphics from the system?
Some Nvidia dGPU’s from the GTX 600 & 700 Series (Kepler family) are natively supported in macOS up to and including Big Sur. Monterey dropped support for these old Nvidia cards.
The Pascal and Maxwell cards 900 and 1000 were never supported natively. Their support came from using the Nvidia Web Drivers (not supported by Apple) and these Web Drivers stopped working with the release of macOS Mojave.
You are wasting your time trying to get a newer version of macOS to work with your GPU.
You need to Install High Sierra or get a compatible AMD GPU.
ok I will install mac os 10.13 but can you help with the config! I will be very grateful.
