Tahoe Beta 2
savage001
192
56
28
44
Adelaide
Ryzen 9 5900X
Has anyone updated to Beta 2 yet?
I’m getting stuck at deferred matching count 3
Reactions: ccphuc
AMDRyzenCPUPowerManagement.kext + SMCAMDProcessor.kext disable
Map corpnewt/USBMap USB Tahoe beta 2 ?
use NootRX.kext not use WhateverGreen.kext
I’ll give that a try now. Can I re enable those Kexts after update?
I actually don’t have AMDRyzenCPUPowerManagement.kext and I don’t use WEG or NootRX.
USB is already sorted for Tahoe.
Reactions: ccphuc
Beta 2 updated fine. AppleHDA is gone though. Injecting it back in via OC doesn't work but VoodooHDA works fine. No changed made to config for beta 2 apart from setting MaxKernel for AppleALC to 24.99.99
FileVault enables after update. Once updated head to settings and wait for it to finish Encrypting, then disable it before rebooting/shutting down or you'll need to disable it via Recovery.
Ok I think Beta 2 is progressing now. I set max kernel for a bunch of Kexts including AppleALC to 24.99.99 and it appears to be working. I set max kernel for AppleALC, USBPorts, OCLP Kexts, NootRX, RadeonSensor, SMCRadeonGPU. Now re enable one by one and see where I can’t boot.
Setting all kext back to no max kernel except AppleALC and I can still bit just fine. Thank you @Shaneee
I do still have a login screen bug though
Has NootRX.kext been updated for Tahoe?
Have you tried using WhateverGreen.kext in place of NootRX?
do that right ? set AppleALC to 24.99.99 ? thank
WEG won't work. NootRX is updated if you download from Actions on Github and confirmed working on my 6800. I also just use device properties for mine.
Reactions: Edhawk
I can't seem to get past the prohibited symbol!. Updated kexts, but still no joy, boots Sequoia 15.5 fine on the 4600G.
Kernel patches are still set with the max for Sequoia. I've changed them and set MaxKernel for AppleALC to 24.99.99 as it's not working on Beta 2 because they've removed AppleHDA. Use VoodooHDA in L/E if you need onboard audio. Make sure you've got the latest kexts from GitHub actions as updated versions aren't "released".
Reactions: craighazan
It was several reasons for me for this to happen, but the weirdest thing was to turn either off or on -V during installation.
After spending the whole day on it, I finally realized it was actually simple — just change all the max kernel values in the AMD processor patches for the 15.x EFI from 24.99.99 to 25.99.99, and make sure not to load WhateverGreen.kext and AppleALC.kext. Then it works.
Reactions: Edhawk
Google Translate has a feature for live translations using your camera. That's how I used it to test.
Reactions: cyrhex
