Use the 4-core vmx.
Could someone reupload opencore 16cores AMD file :
URL is working but cannot download
Mistakenly deleted from hdd and now cannot start VM.
Please reupload on mediafire, upload.ee, workupload or whatever else.
Same situation for every AMD file, even though the site is running and the status says every service is operational, it doesn't allow you to download.
@tucano2000 please upload config opencore files for amd first. They are not too big, please, i need to port some python code to mac app, and the only way for me is in VM.
Thank you very much in advance
Those Fastupload links are a waste of time.
Can't you just upload the files and folders to this site, so we don't have to mess around with spam/ads and ****!
The links to the opencore vmdk image files for INTEL/AMD have been updated on Mega.
The ISO files that are still on fastupload will be updated soon with a new version. In the meantime, you can download the ISO using the Torrent link.
16-core vmx is still linked to Fastupload, even though it says it is linked to Mega.nz.
Is it possible to increase the character limit in a post to more than 10,000 characters?
I'm having trouble uploading Mega links that are a bit longer than fastupload, in which case I need to delete important parts of the tutorial in order to fit them in the same post.
Something for @Shaneee to look in to, as he is the site Admin.
There are some reports that macOS doesn't work internet in Bridge mode and depends on NAT.
It seems that depending on the configuration of the VMWare machine, it can't detect the correct network adapter in automatic mode.
To fix this, do the following:
In VMWare click on Edit and then choose Virtual Network Editor
In the window that opens, select VMNet1 and click Change Settigns.
Now select VMNet0 and then choose the local network adapter used on your host computer in the “Bridged to:' option. The name of the adapter will depend on which type exists on your machine.
Press OK and start your hackintosh.
Reactions: Edhawk
Forum attachements are something like 65MB limit so you could always upload the OpenCore boot images directly to the forum if you want.
Reactions: Edhawk
macOS Sequoia ISO updated to version 15.5
macOS Sonoma ISO updated to version 14.7.6
All now with mega links.
Reactions: Edhawk
Hey all! I have a Ryzen 7950X3D, VMWW 17.x and Sequoia working very well. Thank you for this forum!!! My only apparent issue is this delay. I searched before asking this but could not find anything for 'mouse delay'. When I click a menu, nothing happens. When I click a menu and move my mouse a little, then the menu shows. It does this everywhere. And the highlight does not match where my mouse actually is in the VM. But I hover the mouse where I want to click, and that does still work. Is that a resolution issue possibly? I set my VM to exactly 1/2 of my 4k total resolution of my monitor in full screen. Maybe related to this, in terminal, typing commands is one character off. This is a clean windows 11 pro 24H2 host and fresh vmware with all the patches and fixes from the top of this thread. If nobody is saying anything about this, or calling it something else, what could it be that is behind this issue? To explain the one character off, imagine I went to this line: test 01 and went to delete the space between 'test' and '01'. If I allow myself to move to the space, and hit delete, it deletes the 't' in 'test' rather than the space between which was highlighted. I can 'deal' with that since I know where I need to go to sort this out, it's very odd behavior. Hopefully there is an easy fix to this. Thanks again for all this!!
Reactions: rhcamilex
