Hello everyone. I am trying to install macos catalina on my desktop computer.
CPU: amd FX 8350
Motherboard: M5A99FX pro r2.0
GPU: Sapphire R7 260X 2Gb GDDR5
ram: kingston 8gb
I've been testing different configurations for 3 days. according to opencore.slowgeek.com my config.plist is ok. and I did all of acpi with SSDTTime-master.
this is the output of my log file.
00:000 00:000 OC: OpenCore DBG-060-2020-08-03 is loading in Optional mode (0/0)...
00:057 00:057 OC: Boot timestamp - 2020.08.31 14:13:54
00:107 00:049 OCCPU: MP services threads 8 (enabled 8) - Success
00:153 00:046 OCCPU: MP services Pkg 1 Cores 1 Threads 1 - Success
00:203 00:049 OCCPU: Found AMD FX(tm)-8350 Eight-Core Processor
00:250 00:046 OCCPU: Signature 600F20 Stepping 0 Model 2 Family F Type 0 ExtModel 0 ExtFamily 6 uCode 0
00:400 00:150 OCCPU: FID 25 DID 0 Divisor 1 MaxBR 41
00:447 00:046 OCCPU: CPUFrequencyFromTSC 4013388026Hz 4013MHz
00:497 00:050 OCCPU: CPUFrequency 4013388026Hz 4013MHz
00:544 00:046 OCCPU: FSBFrequency 97887512Hz 97MHz
00:593 00:049 OCCPU: Pkg 1 Cores 8 Threads 8
00:640 00:046 OC: OcLoadNvramSupport...
00:690 00:050 OC: Not deleting NVRAM 4D1EDE05-38C7-4A6A-9CC6-4BCCA8B38C14:UIScale, matches add
00:738 00:047 OC: Not deleting NVRAM 4D1EDE05-38C7-4A6A-9CC6-4BCCA8B38C14
efaultBackgroundColor, matches add
00:787 00:049 OC: Not deleting NVRAM 4D1FDA02-38C7-4A6A-9CC6-4BCCA8B30102:rtc-blacklist, matches add
00:835 00:047 OC: Not deleting NVRAM 7C436110-AB2A-4BBB-A880-FE41995C9F82:boot-args, matches add
00:885 00:050 OC: Setting NVRAM 4D1EDE05-38C7-4A6A-9CC6-4BCCA8B38C14
efaultBackgroundColor - ignored, exists
00:932 00:047 OC: Setting NVRAM 4D1EDE05-38C7-4A6A-9CC6-4BCCA8B38C14:UIScale - ignored, exists
00:982 00:050 OC: Setting NVRAM 4D1FDA02-38C7-4A6A-9CC6-4BCCA8B30102:rtc-blacklist - Not Found
01:029 00:046 OC: Setting NVRAM 7C436110-AB2A-4BBB-A880-FE41995C9F82:SystemAudioVolume - ignored, exists
02:433 01:404 OC: Setting NVRAM 7C436110-AB2A-4BBB-A880-FE41995C9F82:boot-args - ignored, exists
02:489 00:055 OC: Setting NVRAM 7C436110-AB2A-4BBB-A880-FE41995C9F82:run-efi-updater - ignored, exists
02:539 00:049 OC: Setting NVRAM 7C436110-AB2A-4BBB-A880-FE41995C9F82:csr-active-config - ignored, exists
02:585 00:046 OC: Setting NVRAM 7C436110-AB2A-4BBB-A880-FE41995C9F82
rev-lang:kbd - ignored, exists
02:635 00:049 OC: Current version is DBG-060-2020-08-03
02:682 00:047 OC: OcMiscMiddleInit...
02:732 00:049 OC: LoadHandle AEC90798 with BootProtect in Bootstrap mode - Success
02:779 00:046 OCB: Missing FW NVRAM, going on...
02:829 00:049 OCB: Have existing option 1, valid 1
02:876 00:046 OCB: Have existing order of size 8 - Buffer Too Small
02:926 00:050 OCB: Boot order has first option as the default option
02:973 00:047 OC: OcLoadUefiSupport...
03:024 00:050 OCRTC: Wake log is 0xFD 0xFF 255 0xFF
03:070 00:046 OCII: AIFTimerBoostInit Current timer is 549183
03:120 00:049 OCII: AIFTimerBoostInit changed period 549183 to 50000
03:167 00:046 OCII: gST->ConIn BCC81720 vs found BCC81720
03:235 00:067 OCABC: RTDFRG 1 DEVMMIO 0 NOSU 0 NOVRWR 0 NOSB 0 NOHBMAP 0 SMSLIDE 1 WRUNPROT 1
03:282 00:047 OCABC: FEXITBS 0 PRMRG 0 CSLIDE 1 MSLIDE 0 PRSRV 0 RBMAP 0 VMAP 1 APPLOS 0 RTPERMS 0
03:331 00:049 OCABC: Firmware has 2016724 free pages (710101 in lower 4 GB)
03:378 00:046 OCABC: Awaiting rendezvous with OpenRuntime r11
04:782 01:404 OC: RBVR 1 DDBR 1
04:838 00:055 OC: Got 2 drivers
04:887 00:049 OC: Driver HfsPlus.efi at 0 is being loaded...
Any help would be appreciated.
CPU: amd FX 8350
ram: kingston 8gb
efaultBackgroundColor, matches add00:787 00:049 OC: Not deleting NVRAM 4D1FDA02-38C7-4A6A-9CC6-4BCCA8B30102:rtc-blacklist, matches add
efaultBackgroundColor - ignored, exists00:932 00:047 OC: Setting NVRAM 4D1EDE05-38C7-4A6A-9CC6-4BCCA8B38C14:UIScale - ignored, exists
rev-lang:kbd - ignored, exists02:635 00:049 OC: Current version is DBG-060-2020-08-03
