MSI B550M | Sequoia
joanarc
ryzen 9 3900x
Motherboard: MPG B550 GAMING EDGE WIFI
CPU: AMD RYZEN 9 3900X
GPU: AMD RADEON RX 6700XT
Ethernet: Realtek RTL8125 2.5GBit
EFI/
└── OC/
    ├── ACPI/
    │   ├── SSDT-CPUR.aml
    │   └── SSDT-EC-USBX-DESKTOP.aml
    ├── Kexts/
    │   ├── Lilu.kext (V1.7.0)
    │   ├── VirtualSMC.kext (V1.3.5)
    │   ├── AppleMCEReporterDisabler.kext (V1.2)
    │   ├── LucyRTL8125Ethernet.kext (V1.2.2)
    │   ├── NootRX.kext (V1.0.0)
    │   ├── NVMeFix.kext (V1.1.2)
    │   ├── RestrictEvents.kext (V1.1.5)
    │   ├── AMDRyzenCPUPowerManagement.kext (V0.7.2)
    │   ├── AppleALC.kext (V1.9.4)
    │   ├── SMCAMDProcessor.kext (V1)
    │   ├── SMCRadeonSensors.kext (V2.3.0)
    │   ├── USBMap.kext (V1.1)
    │   └── itlwm.kext (V2.3.0)
    ├── Drivers/
    │   ├── HfsPlus.efi
    │   ├── OpenRuntime.efi
    │   └── OpenCanopy.efi
    ├── Tools/
    │   ├── CleanNvram.efi
    │   └── OpenShell.efi
    └── Config.plist
NOTE:
  1. Please create a USBMap.kext using the tool here this is invaluable if you want to boot into Sequoia at all. To get this USBMap.kext you must change your settings inside the tool, make sure it uses native classes.
  2. For some reason, you will not be able to boot into that install hackintosh system after finishing the recovery installer. This was due to having -v debug=0x100 keepsyms=1 in the boot-args but when removing these from NVRAM I was able to boot into the installed hackintosh. All though when using the installer this didn't occur only when I was trying to boot the actual install. It would verbose log then at some point it would have a a lot of uniform text of path applied then it will say successful and restart the system. It will loop this until the NVRAM boot arguments were removed.
  3. Although the screenshot indicates a failed wifi card using airportitlwm, another user in this issue, pointed me to a method for spoofing our wifi card to another then using another kext. I have confirmed this works, Imessage works. method
buenas tardes me podrias pasar la efi gracias
yes I can <3 sorry about the late response i hope this helps you. this should enable seq to have wifi and bluetooth if i remember right, this was due to using some AirportBrcmFixup and doing something jank, I had followed all the airportitwm and gone into indepth research to figure out how to enable wifi using airportitwm.
I dont remember what I did extactly but I remember it being discussed in the issues, I have to find it and ill drop all the knowledge here, which i shouldve done from the start lmao
edit:
you'll have to still follow the method just the part about the pci uncommenting#, then running the root patch, then recomment the pci block
