I’m trying to get network drivers to get it working on vivobook asus laptop x515dap m515da
Deleted member 28458
AMD ryzen 3
I am trying to hackintosh my laptop so I can dual boot it with windows but when I was using opcore simplify it said my network drive was not support at all so I was wondering if there is any way to fix this or I have to go find a .kexts of it
The fix would be to replace it with a compatible Broadcom or Intel WiFi/BT card. Your Realtek 8821CE WiFi/BT card is not compatible with any version of macOS.
Compatible Broadcom WiFi/BT cards, with details of native support and use of OCLP Root Patches.
Compatible Intel WiFi/BT cards using Itlwm.kext & Heliport application.
Dude my laptop is amd not intel cpu but thanks anyway I think I won’t be getting my laptop dual boot macOS but thanks for the help ig
Edhawk is saying if you replace the Realtek WiFi chip with an Intel one it'll work. Not that you've got an Intel CPU.
Ik but I think it’s fine now and I don’t think I can upgrade it or anything because I don’t know if the laptop will open on the bottom or the keyboard
Then you will have to use USB to Ethernet adapter, if your laptop doesn’t have a compatible Ethernet port.
As wireless and Bluetooth will be a dead end with your current Realtek card.
