Acer Swift 3. (SF314-42, AMD Ryzen 4500U) Fine tuning
BCBoy1
39
11
Hello!
I have successfully installed both the Ventura and Sonoma systems on the laptop.
Laptop details in the description!
One thing I can't figure out is why the operating system only loads after 2-3 restarts?
Do you have any ideas?
The USB only works normally with GenericUSBXHCI.kext downloaded from one location.
Even the Wifi works quite well! (BCM94360NG M.2 Wifi) :)
EFI and dsdt attached!
Képernyőfotó 2023-10-11 - 20.39.02.pngKépernyőfotó 2023-10-11 - 20.47.07.pngKépernyőfotó 2023-10-11 - 20.47.41.png
Thanks for any constructive ideas!
    EFI.zip
  • System DSDT.zip
    System DSDT.zip
HI I am currently using Acer Swift 3 sf314-42 same as your device. I've tried copying your EFI to my USB but I can't even get into the screen. Did I forget anything else? Could you please help me
Hi,
There was no Serial info in the EFI.
I added one.
Secure boot needs to be disabled.
The original SSD in the machine will not work. It needs to be replaced.
