For a long time, I've run a Hackintosh on an AMD 3700X CPU. Until lately, it's worked fine running the latest version of Sequoia.
The other day, I tried to upgrade the CPU to an AMD 5900XT (16 cores/32 threads). After swapping the CPU, I first tried accommodating the new CPU by updating the AMD patches with the updated core count (
With that change alone, I couldn't boot to macOS after selecting the OS drive from the OpenCore bootpicker.
After some scattershot debugging attempts, I've at last begun from scratch, following the Dortania AMD guide precisely and updating the AMD patch to this version, which should address Sequoia.
Unfortunately, I still can't get to macOS.
Here's the on-screen error message where booting hangs:
Anyone know what I might try next? I'd really like to get this processor running — I'm sure I'm overlooking something obvious!
Here's my full EFI, including my config.plist. Thanks!
B8 10 0000 0000
and so on).With that change alone, I couldn't boot to macOS after selecting the OS drive from the OpenCore bootpicker.
virtual bool CoreAnalyticsHub::start(IOService *)::139:CoreAnalyticsHub start
Registered CoreAnalyticsHub functions with xnu.virtual bool CoreAnalyticsHub::start(IOService *)::218:CoreAnalyticsHub start completed
[AppleLockdownMode - LDMShouldEnforcePartiy] restoreOS check passted
Kext com.apple.iokit.IOTimeSyncFamily - library kext com.apple.iokit.IOSkywalkFamily not found.
Can't load com.apple.iokit.IOTimeSyncFamily - failed to resolve library dependencies
Kext com.apple.iokit.IOTimeSyncFamily failed to load (0xdc00800e).
Failed to load kext com.apple.iokit.IOTimeSyncFamily (error 0xdc00800e).
Couldn't alloc class "IOTimeSyncRootService"
vh: 4294967168, vl 357548032
AMDCPUSupport::enter link finished.
AppleACPICPU: ProcessorID=0 LocalApicID=0 Enabled
[this list continues up to ProcessorID 31 and then...]
ASP: initializing bastion sandbox callback
no external trust caches found (segment length is zero)
