Partially resolved ! I'm stuck trying to install macOS Sequoia on GA-AB350-Gaming, Ryzen 7 2700X, Radeon RX 550
spakk
33
18
Hello Ryzentosher,
I'm having major trouble installing macOS Sequoia on my system. Here are my hardware specifications:
  • Motherboard: Gigabyte GA-AB350-Gaming
  • Processor: Ryzen 7 2700X
  • Graphics Card: Radeon RX 550/560 Series (4 GB, Polaris 21)
I understand that macOS Sequoia is still in beta, and I realize that certain adjustments are needed to make it run smoothly on all systems. Still, I'd really appreciate any support in getting the installation to boot successfully without getting stuck in an annoying boot loop.
Does anyone have tips or experience on how to get the system to boot stably? Unfortunately, my phone's video quality isn't great, but I hope someone might still have an idea on how to fix the issue.
Error-Loop
Thanks in advance for any help!
Yes they were good days, yourself and @Shaneee were both very helpful with your guides and patched kernels. Bronya and the others too, of course.
Old days, this was first guide I ever tried:
https://www.insanelymac.com/forum/t...odification-installs-on-intel-sse2-or-better/
I have this link with original address for over 15 years in my Safari bookmarks :D:D
After first Hackintosh I bought first iMac, then MacBook Pro.... now I'm again testing to see should I return to macOS again...
  • Haha
Reactions: spakk
Just for curiosity, now your 1060 is just VESA drivers, no support but works from CPU?
I would love to use my 1080ti and not to have 2 gpus inside case.
The installation via USB installer "Install macOS Sequoia_15.2" fails near the end, approximately 12 minutes before completion, with the error message "An error occurred while loading the update."
I need to investigate the cause of this issue. My plan is to re-download the installer from the Apple website, create a new USB installer, and test the process again using the Nvidia graphics card. Interestingly, booting with the Nvidia graphics card worked perfectly fine. The boot time was surprisingly short, and the display appeared completely normal with a resolution of approximately 1920 x 1080 pixels – there was no indication of a lower resolution.
What exactly caused the installation to fail remains unclear at this point. From the sparse information available in the Apple support forums, I’ve learned that several factors could be responsible, ranging from a corrupted installer to incompatible hardware. However, it raises the question of why 70% of the installation process went smoothly, only for an issue to be detected at the very end. It seems unlikely that an incompatible graphics card would cause the process to fail so late – although I might be wrong.
To eliminate any remaining doubts, I will download macOS Sequoia directly from the Apple website again, create a fresh USB installer, and retest the installation with the Nvidia graphics card. If you could also test the installation on an external hard drive or a free partition, that would be fantastic. This way, we’d have two sets of results for comparison
I've recently had a similar issue when using a Sequoia 15.1 USB installer. Installing Ventura and then updating to Sequoia via the Apple OTA option worked for me.
Try downloading Ventura, it will work with my EFI. Sonoma as well. But I've found Ventura gives less issues during the installation. Also if you have a Broadcom WiFi/BT card it will work in Ventura as the BCM drivers are still contained within the OS.
Catalina requires a change to the UEFI > APFS > MinDate and MinVersion entries in the config.plist, as it uses a different version of Apple's APFS. As do Mojave and High Sierra, both have different data for these two entries. Without these MinDate and MinVersion options being changed the OS won't boot. Big Sur and newer don't require any changes to these entries, as the default '0' entry works for all newer versions of macOS.
View attachment 15646 MinDate and MinVersion entries for the three older OS's.
Thank you for this information! I’ll definitely give it a try when the time comes.
InsanelyMac, everyone involved was simply amazing, such a fantastic team!
There were so many contributors that we’d probably need a dedicated page just to list them all. 😊
Reactions: Edhawk
This was my first AMD Hack, HP Microserver Gen 7 (Athlon II Neo N36L CPU) using Nawcom's ModUSB install CD, back in 2013. Still have the CD and the Snow Leopard DVD! I was a long time lurker before registering on IM.
The HP definitely wasn't a UEFI system. My hacks prior to the HP were all Intel based systems.
  • Haha
Reactions: spakk
I can't believe it. The installation of macOS Sequoia 15.2 seems almost complete, and that's with the NVIDIA GTX 1060!
I'm not expecting much compatibility, let alone working graphics acceleration for my GPU, but I'm just hoping the installation finishes successfully so I can move on to testing the Radeon RX 550.😀🙏
Apple made an important change to the file system architecture with the introduction of macOS Catalina: the system volume was split into a "read-only system volume" and a separate, "writable data volume." This measure enhances the security and stability of the operating system, but it significantly complicates modifications to system files such as Kexts (Kernel Extensions) in the "/System/Library/Extensions" directory, making it nearly impossible.
My Previous Attempts and Issues:
Disabling SIP (System Integrity Protection):
The attempt to disable SIP via Recovery Mode with "csrutil disable" and the "authenticated-root" option "csrutil authenticated-root disable" successfully shows the status as "disabled" after a restart in the terminal.
However, editing system directories remains blocked.
Mounting the system volume as writable:
The command "sudo mount -uw /" leads to the following error:
"mount_apfs: volume could not be mounted: Permission denied mount: / failed with 66"
Additionally, copying or modifying files in the system directory, such as with the command
Terminal Code:
"sudo cp -R ~/Desktop/System.kext /System/Library/Extensions/"
also fails.
Request for Assistance:
I hope someone here has already gained experience with this topic and can explain step by step how it is possible to successfully copy or move modified Kexts from my desktop into the "/System/Library/Extensions/" directory.
I think you need to disable 'Gatekeeper' so the system files are accessible.
Download and open Hackintool application v 4.0.3
Navigate to the Hackintool > Utilities tab and select the icon along the bottom of the window that looks like a House.
Screenshot 2024-11-17 at 16.46.46.png Hackintool > Utilities tab - Disable Gatekeeper icon highlighted
After selecting the icon you will need to enter your password.
Then confirm you want to mount the drive in read/write mode.
Screenshot 2024-11-17 at 16.49.29.png Confirmation window
After selecting 'OK' you should be able to access the system files.
Reactions: spakk
View attachment 15659 Hackintool > Utilities tab - Disable Gatekeeper icon highlighted
View attachment 15660 Confirmation window
Thank you for this info! It really shows how long it’s been since I’ve worked intensively with the newer operating systems. A truly great tool! (y)
It seems that Apple has completely locked everything down with macOS Sequoia 15.2. I’ve tried everything, tested every possible terminal command up and down, but the system refuses to grant any access to write to system-related directories. If anyone has an idea on how to solve this issue, please share it here
You may have to read up about APFS Snapshots and see how your system is working with them.
Reactions: spakk
@spakk The original High Sierra Nvidia Web Drivers certificate expired back in 2022. Following initiative and contact from a member over at MacRumours Nvidia released the drivers with a new Certificate. So I would be wary of using any old links to the Nvidia Web Drivers, you need to make sure you use the latest drivers with the new certificate.
That would be the drivers for 10.13.6 (17G14042) (all latest security updates installed) 387.10.10.10.40.140
https://forums.macrumors.com/thread...idia-webdrivers-anymore.2346445/post-31186645
Unfortunately the original download link for the drivers has stopped working. However, you can still download the latest Nvidia Drivers from this link over at Tonymacx86.
I read your post over at InsanelyMac but didn't want to reply there, as they have a zero tolerance of all things TMx86.
Could 1080ti work this way?
I am currently working without full graphics acceleration and can confirm that the system remains extremely stable despite this limitation. There have been no crashes or kernel panics so far, nor have there been any graphical issues. However, there is one limitation:
The animation of the screensaver does not work. During boot, a graphical animation briefly starts but then disappears, leaving a white background. To work around this, I disable the animation and use static wallpapers, which display flawlessly. This allows me to work without any issues.
I have not experienced any problems with Chrome, unlike what other users have reported. I regularly use Safari, Chrome, and Brave, though I primarily prefer Chrome.
Thanks to Shane, who provided a helpful link to bypass access restrictions originally designed for macOS Big Sur, I was able to manually install the web drivers.
However, the process was not successful:
I managed to move the drivers into System/Library/Extensions, create the KernelCache, and regenerate the snapshot. After a reboot, all the previously installed drivers were gone, and the system directories were restored to their original state. It’s possible I made a mistake. I plan to repeat the entire process when I have the chance.
Installing and tweaking with OCAT twice broke my installation. I will never again use tools that modify the system in the background without giving the user a clear overview of what is being changed.
Additionally, booting with a graphics injection (DSDT) or patching the Kext drivers did not provide a satisfactory solution for full graphics acceleration.
Fortunately, I was able to create a 1:1 bootable copy using a detailed Terminal script. Previous attempts to create bootable clones with CCC or SuperDuper failed, as they were not visible during boot.
With the Terminal solution, the process is quick and straightforward, saving me time and making experimentation much easier.
I created an 800 MB EFI partition where I placed all the necessary drivers in EFI/OC/Kext/.
These drivers are linked in the Config.plist, which has so far delivered the best graphics performance.
Thank you for providing the links to the web drivers and CUDA drivers!
At the moment, I’m not entirely sure which version I downloaded. I’d need to boot up my Windows PC to check.
What I do know is that I downloaded and extracted the latest version ending in *140 directly from the NVIDIA website. The same applies to the CUDA drivers.
Ah, the conflict between InsanelyMac and Tonymac, this is a kind of politics I’m happy to distance myself from :ROFLMAO::ROFLMAO::ROFLMAO:
Reactions: Edhawk
I'm making good progress on my project. I successfully patched and installed the web drivers, which is an important step forward. The drivers are now loaded during boot and appear as loaded extension drivers, as shown in the attached image.
However, there are still a few points that need optimization. While the patch works in its basic functionality, I plan to make further adjustments and conduct additional tests to ensure everything runs smoothly and reliably.
One aspect that isn't working as intended yet is the background animation. It currently doesn't start, which might indicate an issue with the patch itself or its implementation. I'll use the upcoming tests to identify the cause and work on a solution.
Once the animation is working, I’ll be one big step closer to achieving my goal. There’s still some work ahead, but I’m confident the remaining issues can be resolved.
Reactions: Law_ri and Edhawk
Reactions: spakk
You'll need more than just patched Web Drivers to get the GPU functioning on Sequoia though. Look at what OCLP does. There's frameworks that need back ported etc.
I wrote a script based on it and will test it later when I’m back home
Reactions: Shaneee
Did you make any new progress? Did you make it work as you wanted?
@Law_ri,
the current macOS build (version 24C5089c) on my Ryzentosh runs largely stable and reliable. Apart from a limitation regarding the lack of full graphics acceleration with my NVIDIA GTX 1060 graphics card, no other significant issues have occurred.
The NVIDIA web drivers are correctly installed and are properly loaded by the system.
However, full graphics acceleration is not completely available.
For example, the screensaver does not work like it would on systems with full graphics acceleration, as background animations are disabled.
Despite this limitation, there are no disruptions in everyday use. Applications such as the Chrome browser run smoothly and without any performance issues.
I am aware that the GTX 1060 does not offer full graphics acceleration on macOS as it is not compatible with the Metal API. As a result, I have already maximized the performance of this card within the given circumstances.
For several weeks, I have been unsuccessfully trying to get my AMD Radeon RX 550 graphics card to work. Every attempt so far has unfortunately failed. Nevertheless, I am still hopeful that I will find a solution.
If this does not succeed, I will part ways with both graphics cards, even though they perform well under Windows. Instead, I will purchase a compatible graphics card for macOS to ensure optimal system performance.
Despite minor limitations, the current configuration of the system is satisfactory for everyday use. However, a functioning RX 550 or the purchase of a suitable macOS-compatible graphics card would be the ideal solution to fully optimize the system.
@Law_ri,
Thanks for info about NVIDIA.
What model of RX550 you have cause I have one and it works perfectly, even have VDA acceleration working.
I switched to use WGE and in device properties I added no-gfx-spoof and device-id 67FF, and in boot args -radcodec and unfairgva=1.
Mine is Asus PH-RX550-4G-EVO, 4GB.
